Results 1 to 3 of 3
  1. Collapse Details
    how do you mount AF100 to Eyedirect HDV???
    #1
    Arrow
    Has anyone used the Panasonic AF100 with the Eyedirect HDV interview gadget???
    I've been unable to mount my AF100 to this device because the Eyedirect HDV baseplate where the AF100 is supposed to screw on to the Eyedirect isn't high enough.
  2. Collapse Details
    #2
    Senior Member Shooter's Avatar
    Join Date
    Sep 2004
    Location
    Auckland , New Zealand
    Posts
    4,335
    Default
    That thing looks adjustable.
    Maybe Use a shim plate to get it higher. Maybe the slide plate from your head.
    The AF100 is pretty standard dimension from base to centre of lens. Thats why its easy to fit rod and base plate systems (and mattaboxes) with minimum adjustment. What camear is that device designed for?
    www.shooterfilm.co.nz
    Adobe CS6 Production Suite, Win7 Pro
    AF102 : RR baseplate & Lens support, F/F, Shoot35 Cinebox, Panasonic 1700HD Monitors. Adaptimax adapters. Ikan VX7e.
    Prime Lenses: Nikkors . 20/f2.8, 24/f2.8, 28/f2.8, 35/f2.8, 50/f1.4, 50/f2, Micro 55/f3.5, Micro 60/f2.8, 85/f1.8, 105/f2.5, 135/f2.8, Contax -Zeiss 28/f2.8, 35/f2.8, 50/f1.7, 85/f2.8
    VariPrimes: Nikkor 17-35/f2.8, 28-70/f2.8,
    GH2. Olympus 14-54 MkII
    Cartoni , Weaver Miller Heads , Miller legs. Slider
  3. Collapse Details
    #3
    Default
    Hi Shooter, I don't have a height adjuster so I went ahead and ordered the 2" riser from vfgadgets. I just saw Philip Bloom's video about the device and saw that he was also using an AF100 with the same 2" riser. The strange thing is that the riser is supposed to be for the 16x9 eyedirect. Yet I know Bloom was using it with the HDV version.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
