http://www.pentaxforums.com/forums/p...ml#post1806546I've used the camera, and there is full manual control in video mode. It just needs to be enabled in the menu and the dial must be set to 'M'. Then you can control shutter speed, aperture, ISO, audio levels, and white balance.
Results 11 to 20 of 33
02-03-2012 06:08 AM
Sony NEX-VG900, 15mm F2.8 , 24mm F1.4, 35mm F1.4, 50mm F1.4, 85mm F1.4 , 165mm F2.8 ,300mm F4, 900mm F5.9 , GH2 , Voigtländer Nokton 25mm f/0.95 , Steadicam Merlin , GH1
02-03-2012 10:00 AM
the video says it's not the same sensor as the K5, but a new design - the K5 is just a year old, and they are both APS-C 16mpix, so I wouldn't expect so, but we'll have to wait and see...
(formerly known as NormanBates)
Flaat Picture Styles for Canon DSLRs
Lens Sharpness Tests - Bokeh Tests - Foto and Video Equipment Recommendations
02-04-2012 09:21 AM
http://www.pentaxforums.com/forums/p...ser-group.htmlWhile many will no doubt continue to discuss about the supposed pros and cons of the camera ad nauseum without even handling the camera, now that I've tried it, have to say I am more than happy to add this camera to my collection because of the commonality of lenses, batteries and user interface with my K-5.
ISO6400_wideopen.jpgActual image from the K-01 - high ISO snapshot (ISO6400 at f/2.8) in a very dark setting handheld.
http://www.pentaxforums.com/forums/p...ml#post1809059I have a K-01 (pre-production) with me right now. From the menu, you can set video exposure control to either 'P/Av/M' mode, movie format can be set to FullHD/HD/VGA in 30/25/24fps and Quality Level of ***/**/*. Can also adjust recording sound level (for both internal or external mic), can enable/disable SR, can shoot interval videos, can do AF by either press the shutter button or AF/AE-L button (customizable) ...Last edited by joe1946; 02-04-2012 at 09:36 AM.
02-05-2012 06:06 PM
The K-01 seems to be a good deal but I am most worried about the lack of an EVF or tiltable screen.
If they had put in either one then I wouldn't be too bad about it.Last edited by Boncrek; 02-06-2012 at 05:48 PM.
02-05-2012 06:06 PM
*Double Post*
02-06-2012 11:28 AM
02-06-2012 11:31 AM
02-06-2012 11:48 AM
... but much worse than the one on the K5, which has the same low light abilities but much (MUCH) better dynamic range and somewhat better tonal range
http://www.dxomark.com/index.php/Cam...and3%29/Pentax(formerly known as NormanBates)
02-06-2012 05:50 PM
Sorry I meant K-01, I edited my post.
The K-01 does not have an EVF or a tilt option for its screen, limiting it to 7D-style ergonomics and requiring an external monitor for anything more than eye level type shots. Thats a big no no for most of the DSLR crowd nowadays especially new adopters.
02-09-2012 09:59 AM
first bit of info about the codec: it seems to have a relatively low bitrate, around 21 Mbps including audio: http://www.pentaxforums.com/forums/p...ml#post1818161 - not nice, but it's a pre-production model, maybe the final spec could change this (even so, I doubt it would get to 28 or higher)
