Results 1 to 7 of 7
  1. Collapse Details
    Ideal Export Settings?
    #1
    Senior Member Brickhouse's Avatar
    Join Date
    Dec 2008
    Location
    Calgary, Alberta, Canada
    Posts
    287
    Default
    Hey
    What are the ideal export settings? Thank you.
    Check out my webcomic and support the SPCA!
  2. Collapse Details
    #2
    Senior Member taylormade's Avatar
    Join Date
    Jul 2003
    Location
    St.Louis area, USA
    Posts
    499
    Default
    What's the format of your entry?
    "If they move, kill'em!"
  3. Collapse Details
    #3
    Senior Member Hawk Teflon's Avatar
    Join Date
    Nov 2005
    Location
    Mustang, Oklahoma
    Posts
    3,281
    Default
    What are you editing on?
  4. Collapse Details
    #4
    Join Date
    Dec 2008
    Location
    Posts
    287
    Default
    Fcp
  5. Collapse Details
    #5
    Join Date
    Nov 2005
    Location
    Mustang, Oklahoma
    Posts
    3,281
    Default
    My default is to use
    File>Export>Using Quicktime Conversion
    Set the 2nd dropdown (should be "Default" or "Most recent settings") to LAN/Intranet. This will give you an H.264 with good quality, but it jacks up your size.
    Options>Size>(Then select the size you want from the drop down, or create your own)
    This option rarely exceeds 100Mb, so you should be good.
    That's a good basic default export.
    Also, you can File>Send to>Compressor
    Once in compressor, you can change the bitrate / size / etc and it'll give you an "estimated file size" in your info window. This will let you bring things up or down to get the right file size.
    The second takes more work, but you have more control over your file size.
  6. Collapse Details
    #6
    Join Date
    Jul 2003
    Location
    St.Louis area, USA
    Posts
    499
    Default
    Sorry, I'm an Avid guy. Looks like Hawk has the answers you need.
  7. Collapse Details
    #7
    Join Date
    Dec 2008
    Location
    Posts
    287
    Default
    thanks babe
Posting Permissions
  • You may not post replies
  • You may not edit your posts
