Lots of info out there.
still unclear as to why AVCHD is harder.
both formats require log and transfer, but AVCHD needs to be transoded.
ok, i got that.
but during the log and transfer for DVCpro, it spits out .mov files, so its doing some kind of conversion right?
both formats go thru a conversion before editing, but AVCHD takes just takes a longer due to transcoding.
so then, when people say "DVCpro is easier", it just means it takes less time during that one step. I haven't found anything about why else AVCHD would be more difficult.
Do i have this correct?
thanks!
Thread: Why is AVCHD harder than DVCpro
Results 1 to 10 of 11
Junior Member
- Join Date
- May 2010
- Posts
- 21
10-15-2011 04:40 PM
10-15-2011 05:19 PM
I guess it's 'harder' with FCP (older versions and especially PowerPC Mac's)... I edit the native AVCHD files in Vegas all day long, no worries. Pop the SD card out of the camera, copy the folder to a drive, drag the files on the timeline...and go!
On my old (funny, cause it's really not THAT old) G5 PowerPC & FCP 6, I have to use Toast 10 to convert the files to ProRes before editing.
Senior Member
- Join Date
- Dec 2010
- Location
- San Diego
- Posts
- 555
Senior Member
- Join Date
- Aug 2008
- Location
- USA
- Posts
- 1,690
10-15-2011 09:33 PM
No. What people mean by that is that decoding DVCPRO HD during playback is easier on the CPU because every frame is independently recorded, as has been the norm for film and SD video forever (and is still used for DVCPRO HD and AVC-I). But with high definition video, a lot of formats (like HDV and AVCHD) don't record every single frame as a whole frame. Those formats use something called interframe or temporal compression, which is a lot more difficult to decode (and which you can read about with some Googling).when people say "DVCpro is easier", it just means it takes less time during that one step. Do i have this correct?!
That Final Cut Pro is a bit behind the times and can't handle the native footage is unrelated to what people are talking about when they say DVCPRO HD is easier.
Senior Member
- Join Date
- Jul 2007
- Location
- Toronto
- Posts
- 2,789
10-16-2011 06:04 AM
Here is the link to download the free Panasonic Final-Cut Pro plug-in that enables native editing of AVCHD .MTS files with NO transcoding at all. This makes editing AVCHD video files with Final Cut Pro a lot easier:
Panasonic AVCCAM Importer Download LinkCameras : Panasonic GH3 with Grip, Panasonic GH2, Panasonic HMC-150
OIS Zoom : Lumix 12-35mm f/2.8, Lumix 35-100mm f/2.8
Junior Member
- Join Date
- May 2010
- Posts
- 21
10-16-2011 07:35 AM
Nice, i didn't know about the avccam importer, but it seems like it still requires rendering to play in FCP timeline.
i have never worked with a rendering workflow before, so def want to avoid that.
i just posted another topic in the post-production section about some tests and comparisons i did this morning concerning the different codecs. appropriate to mention the results here. conclusion is, differences in quality and performance during editing are quite negligible on my machine. disappointing
http://www.dvxuser.com/V6/showthread...71#post2450971
thanks!
Senior Member
- Join Date
- Jul 2007
- Location
- Toronto
- Posts
- 2,789
10-16-2011 03:02 PM
I'm not a Mac user, but I had thought that this plug-in will enable you to play unmodified AVCCAM video clips from the Final Cut Pro timeline. So this isn't the case ?
I could understand if you had to render modified footage ( most CPU / GPU combos don't have the procesing power to process HD video modifications in real-time ), but even unmodified footage won't play without rendering ?Cameras : Panasonic GH3 with Grip, Panasonic GH2, Panasonic HMC-150
Senior Member
- Join Date
- Dec 2010
- Location
- San Diego
- Posts
- 555
10-16-2011 03:07 PM
I haven't tried out the Panasonic plugin yet, but I was unable to get real-time editing using ClipWrap on AVCHD video on my 3.4ghz i7. I think there are some severe limitations to the 32-bit code and rendering engine of Final Cut. I could sometimes get video to playback on my external monitor in real time, but only if there were no effects added.
Have zero problem editing native AVCHD under Premiere Pro or FCPX.I shoot everything on 8mm tape. BALLER STATUS
Senior Member
- Join Date
- Aug 2008
- Location
- USA
- Posts
- 1,690
10-17-2011 11:04 AM
Both of those a 64 bit apps.
Junior Member
- Join Date
- Oct 2011
- Posts
- 2
10-24-2011 06:20 PM
Do you think Premiere would handle AVCHD on a 2.66 GHZ core duo?
