Results 1 to 10 of 10
  1. Collapse Details
    Flash burn transition
    #1
    Senior Member chromeboy007's Avatar
    Join Date
    Aug 2005
    Location
    Toronto
    Posts
    843
    Default
    Here is a free transition plugin that I loved with FCP, Too Much Too Soon's Flash Frame. Unfortunately those guys don't make them for PP, I can't even pay for it. I wonder where I can download it. I can pay some cash for it, but I'm not sure if I want to pay for a package from like NewBlueFX like this one which is as close as I can get to what I want: http://www.newbluefx.com/light-blends.html
    Anywhere else I can go?
  2. Collapse Details
    #2
    Senior Member mmka1985's Avatar
    Join Date
    Aug 2010
    Location
    Illinois
    Posts
    350
    Default
    You can try to create it yourself experimenting with effects in Premiere Pro. Some of the best effects and transitions I've created have been from fiddling around and such. I will agree that Premiere Pro option for transitions are nowhere near FCP and if u want cool transitions u have to be on a PC
  3. Collapse Details
    #3
    Join Date
    Aug 2005
    Location
    Toronto
    Posts
    843
    Default
    Hey yeah I thought about that, with AE though not Premiere.
  4. Collapse Details
    #4
    Join Date
    Aug 2010
    Location
    Illinois
    Posts
    350
    Default
    Actually you can do it with both. Play around with your effects and you will be surprised what you can come up with in Premiere. AE would be the most obvious but Premiere is a program you can't underestimate. It has loads of potential and people are finally starting to see that. But you are still learning so experiment with what you got before you rely on third party products to be ur end all be all solution
  5. Collapse Details
    #5
    Dark Side of the Camera Postmaster's Avatar
    Join Date
    Nov 2007
    Location
    Germany
    Posts
    5,189
    Default
    frankglencairn.wordpress.com
    http://twitter.com/FrankGlencairn
    Real men edit their films in a hex editor.
  6. Collapse Details
    #6
    Default
    You can also make your own. From Ann Bens:
    You will have to make it your self.
    First clip add the Fast Blur effect and the Levels effect.
    10 frames from the end set keyframes for bluriness, RGB white input and RGB gamma.
    5 frames from the end set RGB Gamma to 50.
    Now go to the last frame and set RGB white input to 0 and bluriness to 20.
    For the second clip place same effects and set keyframes in reverse.
    (first frame bluriness 20, RGB white input 0 etc.)
    When ready you can make a Preset out of the effects.
    Kevin Monahan
    Social Support Lead - DVA
    Adobe
  7. Collapse Details
    #7
    Join Date
    Aug 2010
    Location
    Illinois
    Posts
    350
    Default
    Quote Originally Posted by Kevin Monahan View Post
    Exactly my point. Thanks Kevin
  8. Collapse Details
    #8
    Join Date
    Aug 2005
    Location
    Toronto
    Posts
    843
    Default
    Ha! Thanks Kevin and everyone else!
    http://www.youtube.com/watch?v=xeTyE_8wl-8
    This is way cool... it's like a new door has just been opened. I'll play around with this and explore some more.
  9. Collapse Details
    #9
    Default
    Very cool! I like the tilt shift stuff too.
    Kevin Monahan
    Adobe
  10. Collapse Details
    #10
    Join Date
    Aug 2005
    Location
    Toronto
    Posts
    843
    Default
    Thanks Kevin.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
