Page 1 of 2 12 LastLast
Results 1 to 10 of 16
  1. Collapse Details
    Need P2 info verified
    #1
    Senior Member PappasArts's Avatar
    Join Date
    Oct 2004
    Location
    Newport Beach CA, USA
    Posts
    2,337
    Default
    Is this data correct or at least in the ballpark? If not, can someone correct it. Thanks
    1080P 24fps: around 13 minutes
    1080 60i : around 4 minutes
    720P 24fps : around 13 minutes
    720P 60P: around 4 minutes
    "The talent of an artist is never measured on how real they can create something, it's on how much life they can give it"
  2. Collapse Details
    #2
    Hottie Mod NoahK's Avatar
    Join Date
    Sep 2003
    Location
    LosAngeles
    Posts
    4,639
    Default
    For which media size? Plus I suspect it will be tough to truly verify anything until NAB.
    One of 50 Best Websites for Moviemakers by MovieMaker Magazine: www.CallBoxLive.com
    40% discount code for DVXusers: dvxcbx20
    Good on all Call Box videos including Panasonic GH2, Panasonic AC160/130 and GoPro HD.
  3. Collapse Details
    #3
    Default
    Also keep in mind that the 1080 24p will be written to a 60i stream like the DVX does with SD. Jan mentioned that it one of these threads.
    Do not seek to follow in the footsteps of the men of old; seek what they sought.
    -Matsuo Basho
  4. Collapse Details
    #4
    Join Date
    Oct 2004
    Location
    Posts
    2,337
    Default
    The 4gig card. Thanks!
    QUOTE=NoahK]For which media size? Plus I suspect it will be tough to truly verify anything until NAB.[/QUOTE]
  5. Collapse Details
    #5
    Join Date
    Sep 2003
    Location
    LosAngeles
    Posts
    4,639
    Default
    Hard to say as I'm still unclear whether the 24p modes will actually write to P2 with their pulldown or at their native frame rates.
    Noah
  6. Collapse Details
    #6
    Join Date
    Oct 2004
    Location
    Posts
    2,337
    Default
    So the only 1080P will be 24 and 30 fps. I can't wait to use the 720 60p for effects work.
    Quote Originally Posted by Shaw
  7. Collapse Details
    #7
    Join Date
    Oct 2004
    Location
    Posts
    2,337
    Default
    Your right, because if it's true 24p to P2 then that changes it vs maybe a 60P with flagged frames. Well, it's only a few more days tell we get many answers.
    Quote Originally Posted by NoahK
    Noah
  8. Collapse Details
    #8
    Join Date
    Sep 2003
    Location
    LosAngeles
    Posts
    4,639
    Default
    It seems logical either way. I'd be more in favor of the native frame rates. If you think about it there's really no place you could play a P2 back other than the camera or in an NLE. Both of which would be capable of adding the pulldown.
  9. Collapse Details
    #9
    Default
    But will it be written on the card that way... that's the question. Or will it know how to delete the "C" frame...
    I expect that if there's firewire streaming, it'll send the full 60i stream out the firewire port, but for recording on card, I think there's a possibility they may know how to drop the "C" frame and record 80mbps... or maybe they just record the whole stream because there is no provision for flagging "active frames" in 60i in any other form of DVCPRO-HD recording...
  10. Collapse Details
    #10
    Join Date
    Sep 2003
    Location
    LosAngeles
    Posts
    4,639
    Default
    Oh definitely out the FW port(assuming it has one) it will have to be 60i at all time in order to be usable. It would be great to have the option to write to P2 with or without pulldown.
    Noah
Posting Permissions
  • You may not post replies
  • You may not edit your posts
