Just want to emphasize Ryan's point about not touchign the bulbs. I was on a set for a short a few days ago and one of the bulbs in our HMI exploded. Nobody hurt, but if there hadn't been a lens in front of it, could have been a different story. Shooting glass into an actor's face is never a good idea.
See the top rated post in this thread. Click here
Thread: HMI: how not to die
Results 11 to 17 of 17
Junior Member
- Join Date
- Mar 2011
- Location
- British Columbia, Canada
- Posts
- 17
04-01-2011 04:00 PM
06-10-2011 01:25 PM
Not even when it's very, very hot glass?
Lots of toys... that I barely know how to turn on
11-24-2011 05:41 PM
When you have an HMI on, I know it's best to keep it on for the bulb. However, say you go for your hour lunch, you don't need to move it for the next shot, and you don't need to turn it off, what's the best thing to do? Do you keep it on or turn it off and re-strike it after lunch? I've heard the former (leave it on) but I just want to confirm this.
"Dialogue should simply be a sound among other sounds, just something that comes out of the mouths of people whose eyes tell the story in visual terms." - Alfred Hitchcock
Senior Member
- Join Date
- Mar 2011
- Posts
- 153
12-30-2011 06:40 PM
I have heard that striking the bulb is equal to anywhere from 1 to 3 hours o lamp life. I try to avoid turning off the lamps for anything less than an hour. Also even though an instrument may clim to do a hot restrike, chances are it won't when you need it to. Also if working outside in a possible wet environment you might want to look into putting everything on gfci's.
12-14-2012 07:11 AM
This Post Needs To Be Made STICKY!!!
Just one little FYI aside. "HMI bulbs are supposed to be 5600k" not true. They can be any color and I prefer 4300k. HMI is actually a branded version of HID. They are the same exact Metal Halide type bulbs. HMI was coined by Osram and became synonymous with 'motion pictures'. Your advise about circuit draw is SPOT on! I would suggest if this goes sticky, that you insert a side-bar explaining how to calculate load on a circuit using the tried and true formula for calculating Amps drawn versus Amps available. Just saying 1.2KWatts per circuit is too imprecise. Finally. NEVER tamper with the Ballast or wires leading out of the ballast to the bulb assembly- when the unit is still 'Live'. The ballast converts input into 25,000V bursts ;) Thanks for laying this out so lucidly!
