Page 2 of 7 FirstFirst 123456 ... LastLast
Results 11 to 20 of 61
  1. Collapse Details
    #11
    Default
    The embedded version of Will still doesn't have sound...
    The downloaded version does have sound. Let's hope people take the time to download it!
    Kevin
    Kevin E. Curry
    Writer * Producer
    Lyon Films - Portland, ORwww.LyonFilms.com
    Will
    2011 FictionFest
    The Slice
    Finalist 2010 BetrayalFest
    The Tell
    Winner "Creative Vision Award" 2009 MonsterFest
    Tarts, Fools & the G-Men
    Winner "Best Newcomer" 2009 QuestFest
  2. Collapse Details
    #12
    Fest Master Larry Rutledge's Avatar
    Join Date
    Aug 2004
    Location
    Winters, CA, USA
    Posts
    5,481
    Default
    @Joshua - interesting, as it's using the same code in both places to trigger a force download of the file. However, I will check the source again to ensure it's pushing the file for download as it should. Thanks for the heads up.
    @Kevin - it's actually the same file. As indicated on the viewing page, the streaming system is still a beta system. As such there will be glitches along the way. Unfortunately 'Will' is encoded using an audio codec that our player is unable to process. Downloading and playing locally works fine, but the player does not. I will get it re-encoded, but in the meantime people will need to download the file.
  3. Collapse Details
    #13
    Senior Member Robert Eldon's Avatar
    Join Date
    Feb 2006
    Location
    Murrieta, CA, USA
    Posts
    886
    Default
    I'm having trouble unzipping 'fiction0001.zip'. I've downloaded it twice now, but get a message 'The compress (zipped) folder is invalid or corrupted' when trying to 'unzip' it.
    Thanks.
  4. Collapse Details
    #14
    Senior Member Joshua Brown's Avatar
    Join Date
    Jul 2009
    Location
    Los Angeles, CA
    Posts
    143
    Default
    This one is a little selfish, but my Poster does not show up on the Streaming Viewer. (Everything Is Better)
  5. Collapse Details
    #15
    Join Date
    Aug 2004
    Location
    Winters, CA, USA
    Posts
    5,481
    Default
    @Robert - I'll look into it .. have you been able to open any of the other zips?
  6. Collapse Details
    #16
    Join Date
    Feb 2006
    Location
    Murrieta, CA, USA
    Posts
    886
    Default
    Quote Originally Posted by Larry Rutledge View Post
    Yes, all of the others unzip with no problem.
  7. Collapse Details
    #17
    Join Date
    Aug 2004
    Location
    Winters, CA, USA
    Posts
    5,481
    Default
    @Joshua - fixed .. your poster is there now
    @Robert - ok, thanks ... I'll check it. In the meantime you might try once more ... there are a couple mirrors, so it could be bad on one and not the other. I'll try to figure out which one is wrong and re-build it.
  8. Collapse Details
    #18
    Join Date
    Jul 2009
    Location
    Los Angeles, CA
    Posts
    143
    Default
    I have had two failed download attempts on fiction0003.zip It errors in Safari with the message "decompression failed" at around 20mb.
  9. Collapse Details
    #19
    Senior Member hansel960's Avatar
    Join Date
    May 2007
    Location
    Marina del Rey
    Posts
    100
    Default
    i'm getting no sound when streaming (vomit). downloading now.
  10. Collapse Details
    #20
    Join Date
    Feb 2006
    Location
    Murrieta, CA, USA
    Posts
    886
    Default
    I've tried a number of times and still can't unzip fiction0001.zip. It always comes from dvxfest.day7studios.com if that helps.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
