Has anyone done comparison tests of when to use this? I usually want to keep the picture as free from post-processing as possible, but if it helps....
Results 1 to 6 of 6
03-04-2011 07:34 PM
Dave
Fear and Loathing in Raleigh, NC
www.vimeo.com/greeches
www.youtube.com/greeches
"Art of seduction, Alcohol introduction."
"A man who looks where he walks, never steps in sh*t."
Senior Member
- Join Date
- Dec 2010
- Location
- Los Angeles
- Posts
- 396
03-04-2011 10:34 PM
Why don't you do your own tests? It's only five settings.
But, if you want someone else's opinion, I've concluded that the camera's noise reduction is bad, and I leave it permanently set at -2.
The problem is, it doesn't really reduce noise, it just smears it around. And it smears out fine detail in the process. There are far more sophisticated ways to remove noise in post, which don't destroy the fine detail.
But, if you don't want to do any post processing, and you want a noise free picture, light your scenes so you can shoot at iso 400 or slower.
Senior Member
- Join Date
- Nov 2009
- Location
- Cary, NC
- Posts
- 1,285
03-07-2011 05:01 AM
+1 on trying it out for your self. However, if you want the short answer. The noise reduction settings are not good and in some cases they actually apply noise reduction to the RAW sensor image before any other processing happens. I turn it to -2 for all but the smooth color setting. I only use that setting in desperation when I am using the ETC mode in low light and I really don't want to do any post processing at all. Otherwise you should never use it.
Panasonic DMC-GH2 movies
http://www.youtube.com/user/mpgxsvcd#play/uploads
http://vimeo.com/user442745
Senior Member
- Join Date
- Nov 2010
- Posts
- 107
Senior Member
- Join Date
- Dec 2010
- Location
- Los Angeles
- Posts
- 396
03-07-2011 07:31 PM
Nice tips! I'll have to try that in Neat. I usually just sit and tweak.
Yea, I've turned mine to -2 aswell. I did some low light tests in my living room, but I didn't notice much of anything.
Dave
Noise Reduction (NR) Settings (-2 to +2)
