Thread: Battery advice?
Results 1 to 7 of 7
  1. Collapse Details
    Battery advice?
    #1
    Default
    I was looking at using the 96w batteries that are popping up on ebay and listed on B&H. It looks ideal to power the cam plus a KiPro considering they have a powertap. Maybe not ideal for handheld but otherwise it seems ok. It says they will charge with the stock charger too.
    http://www.bhphotovideo.com/c/produc...thium_Ion.html
    On ebay they are popping up for around $190 but are a different brand, although feedback ratings look good.
    Any opinions?
  2. Collapse Details
    #2
    Senior Member Jason Davenport's Avatar
    Join Date
    Nov 2008
    Location
    Dallas, TX
    Posts
    680
    Default
    Those are great for the EX-3, but the F-3 is a 4 pin. That has the small EX-3 power pin. I'd call them and see if they are working towards a 4 pin for the F-3 or an adapter to go to 4 pin.
    On a EX, one of those suckers will last half the day.
  3. Collapse Details
    #3
    Senior Member
    Join Date
    Sep 2006
    Location
    Vancouver, BC
    Posts
    576
    Default
    All those Swit batteries have a D-Tap (Anton Bauer Power Tap connector) on them as well. If you have one of these cables...
    http://www.bhphotovideo.com/c/produc...XLR_Power.html
    ... you can get this to work. You will have that EX3 cable dangling but otherwise the battery will work.
  4. Collapse Details
    #4
    Default
    I've made some pro cables in the past and it doesn't seem like too big a deal to put a 4pin on there in place of that little plug. (Why does it need more than 2 pins for power anyway?)
  5. Collapse Details
    #5
    Senior Member Duke M.'s Avatar
    Join Date
    Aug 2008
    Location
    CA & FL
    Posts
    2,360
    Default
    I've been told it doesn't need 4 pins but it keeps you from confusing power XLR cables from 3 pin mic XLR cables.
    That Marshall cable is way over priced. There's nothing special about those power cables. I've seen them as low as $18. Here its $22 including shipping.
    http://cgi.ebay.com/Male-D-Tap-Femal...item2a0e46120a
  6. Collapse Details
    #6
    DVXuser Sponsor
    Join Date
    May 2004
    Location
    Lexington, USA
    Posts
    720
    Default
    Quote Originally Posted by JDDalllas View Post
    Here is the cable to adapt the battery to XLR4
  7. Collapse Details
    #7
    Join Date
    Nov 2008
    Location
    Dallas, TX
    Posts
    680
    Default
    And here the actual cable from Switronix for that battery as well.
    http://www.switronix.com/products/ba...category_id=45
Posting Permissions
  • You may not post replies
  • You may not edit your posts
