Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
  1. Collapse Details
    #21
    Senior Member JMtheDP's Avatar
    Join Date
    Feb 2013
    Location
    United Kingdom
    Posts
    1,415
    Default
    24 fps with a 1/48th shutter = 180 degree shutter. It relates to a film shutter, which being a mirror is best measured in degrees. Much better way of doing it than fractions. Lots about this online.
    James Martin, UK-based DoP
    www.jamesmartindop.com
    Sony F65, ARRI/Zeiss Master Primes, ARRI Alura Zooms
    Formerly: F900, F35, Zeiss Standard Speeds, Illumina S35s...
  2. Collapse Details
    #22
    Senior Member
    Join Date
    May 2010
    Posts
    2,404
    Default
    There is a black interval between video frames too. True 24 fps flickers horribly on electronic displays. The normal refresh rate for TV displays these days is at least 120Hz: 5x per 24 fps progressive frame, 4x for 30fps, not including any "smooth motion" interpolation BS. This eliminates the need for 3:2 pulldown conversion at 60Hz NTSC rates.
  3. Collapse Details
    #23
    Senior Member
    Join Date
    Aug 2012
    Location
    Worldwide
    Posts
    2,876
    Default
    Quote Originally Posted by JMtheDP View Post
    ...which being a rotating disc, is best measured in degrees.
    New Website: www.liamhall.net
    TWITTER: @FilmLiam
    INSTAGRAM: @picsbyliam
  4. Collapse Details
    #24
    Join Date
    Feb 2013
    Location
    United Kingdom
    Posts
    1,415
    Default
    Quote Originally Posted by Liam Hall View Post
    You are correct, that'll teach me for posting after a long drive
    I would say they are spinning disc mirrors, but not all are - some are just there to blank the sensor.
    I believe the Viper had a spinning mirror in it, despite having no optical look-through
Posting Permissions
  • You may not post replies
  • You may not edit your posts
