Yes, that's probably my favorite aspect of there being two slots. I don't really anticipate needing 24 hours of recording capacity loaded in the camera at once, but the ability to extract selected clips and make a new card is pretty cool.
See the top rated post in this thread. Click here
Thread: AF100 tips, tricks, and FAQs
Results 21 to 30 of 73
Moderator
- Join Date
- Sep 2003
- Posts
- 49,274
03-11-2011 08:50 AM
Junior Member
- Join Date
- Mar 2011
- Posts
- 1
03-14-2011 10:59 AM
I have a canon 50mm FD mount I cant set the stop on, despite having the Lens Check set to off. Whether the stop is set at 1.4 or 16, I can see no difference in the viewfinder or on the recorded image.
Im using a rainbow fd to micro 4/3 adapter - my other Fd mount lens is a Canon 70-210 zoom, and does not have the same issue. Any ideas why I cant set the stop on my 50mm? Thanks for any help!
Moderator
- Join Date
- Sep 2003
- Posts
- 49,274
03-14-2011 11:38 AM
Not familiar with that lens, but I presume it has a manual aperture ring? Perhaps the aperture blades are stuck? Or there's maybe a DOF preview button that needs to be pressed?
03-18-2011 12:52 PM
Likely you have figured this out by now, but I had the same issue...the problem is when mounting the lens onto the adapter there is a little pin(on the adapter) that has to engage a tab on the lens...it is easy to accidentally attach the lens without the pin moving the tab.
Hope it helps!
Bob"...almost any story is almost certainly some kind of lie." Orson Welles
03-18-2011 01:09 PM
Photos to illustrate canon fd attachment...when mounting the lens the pin that is seen inside the novoflex adapter needs to slide the lens aperture tab as you mount the lens to adapter.novoflexfdm43circled.jpgcanonfdmountcircle.jpg
Junior Member
- Join Date
- Apr 2011
- Posts
- 11
04-04-2011 03:00 PM
Thanks Barry, this helps me a lot course I would verry mutch like to shoot 24p on the Atomos 'Samurai' , lets hope it understands to record in 1080-24p from the output SDI , further I will have to keep in mind now I can't shoot autofocus at that time. the HDMI disable and variable framerate is not a huge problem to me course I do not expect the 'Samurai' to be able of recording variable framerate and the HDMI I wont need at time of recording.
- Join Date
- Jun 2009
- Location
- Kent,UK
- Posts
- 31
06-13-2011 01:31 AM
Has there been any word on expanding the functionality of the dial to include film speed/ISO sensitivity? I know others have been asking, but I didn't know if Panasonic has definitively answered on if it is even possible or expected as a firmware update. It is certainly awkward while trying to maintain DOF when light changes to have to drill into menus to get to the sensitivity/iso settings for in between the pre assigned boost switch settings.
Jan??? Barry???http://www.vimeo.com/daleanthonysmith
http://www.youtube.com/user/multimed...ature=mhee#p/a
AF100, GH1(pair), Lumix Lenses: 20mm, 7-14mm, 14-140mm, 100-300mm Nikon Lenses: 55mm macro f3.5, 50mm f1.4
CS5 workstation 24gb RAM, ProAim Mattebox w/ 4" filters, CobraCrain Jib w/motor pan/tilt on Quickset Herculese jibpod
Moderator
- Join Date
- Sep 2003
- Posts
- 49,274
06-13-2011 08:35 AM
I have heard nothing about any such change coming. Again, traditionally there have been no feature enhancements for existing models.
