Page 1 of 3 123 LastLast
Results 1 to 10 of 25
  1. Collapse Details
    Zoom H4n - best settings for recording dialog
    #1
    Senior Member
    Join Date
    Mar 2010
    Location
    Dublin
    Posts
    176
    Default
    What are the recommended settings (ie. Stereo, 4CH or Mtr mode as well as various settings, etc.) on the Zoom H4n when recording dialog?
    It is my understanding that mono audio is best suited for dialog instead of stereo audio. Is this correct?
  2. Collapse Details
    #2
    Senior Member
    Join Date
    Apr 2010
    Posts
    592
    Default
    mono, 24bit/48khz (96 if possible)
  3. Collapse Details
    #3
    Senior Member
    Join Date
    Mar 2010
    Location
    Dublin
    Posts
    176
    Default
    I suppose that to switch to mono I need to be in MTR mode?
  4. Collapse Details
    #4
    Senior Member Sam Mallery's Avatar
    Join Date
    Mar 2010
    Location
    Durham, NC.
    Posts
    363
    Default
    I don't use MTR mode on the H4n. That's the multi-track mode, made for overdubbing. Why mess with that when you don't have to?
    I set mine at 48kHz 24bit, and use Stereo mode, even if I'm only plugging in one mono microphone. It's not stereo if there is only one channel. It may be recording a blank track, but blank tracks don't eat up very much space on a memory card. 4CH mode is usually unnecessary. It doesn't do the production much good to have a recording of stereo sound away from the action on the built-in mics in my bag.
  5. Collapse Details
    #5
    Senior Member Petros Kolyvas's Avatar
    Join Date
    Sep 2009
    Location
    Montreal, QC
    Posts
    418
    Default
    Quote Originally Posted by Sam Mallery View Post
    I use 4 channel mode all the time now (that I've been schooled on another forum) to track 4 isos out of my 552. I usually only use 4 tracks on a "normal" day. I have the 552 direct outs setup as mic-level pre-fade when using the H4n.
    There's a mini-TRS (3.5mm) plug underneath the unit below the on-board mics which, when used, allows for input of two additional channels. CORRECTION: replaces the on-board mic channels with external inputs. Thus it becomes quite the decent 4-channel backup recorder. It's just in case the mix sent to camera needs some kind of fixing but I've found the recordings to be useable.
    I had a custom cable made for the job; if you're a do-it-yourselfer (and using an SD mixer) you need to short pin 1 and 3 on both XLR inputs and tie them to the sleeve of the mini TRS jack. Then Tip-Left hot (Pin 2), Ring-Right hot (Pin 2). The cable I had ordered came with the cold terminals of the XLR inputs floated and I had to modify them to get rid of some awful ringing.
    Now, however, it's been tested and works wonderfully. For anyone using a 552 (or a 442 or 302 I imagine) my H4n "gain" settings are 27 for the "mic" input and "41" on the XLR inputs when the signals from the mixer are mic-level. At this point -20dBFS lines up on both units and the 552 input limiters (if engaged) kick in just before the H4n clips. I can now just hook it up and go!
    There is no intuitive interface, not even the nipple. It's all learned. -Bruce Ediger
    SLR'd WRDS
  6. Collapse Details
    #6
    Senior Member markblasco's Avatar
    Join Date
    Sep 2009
    Location
    Seattle, WA
    Posts
    263
    Default
    I believe this is not correct (although someone can chime in if I am wrong). Recording a blank audio track as a WAV will use the exact same amount of space as recording someone talking. It is still recording the same numbers of 1's and 0's, although since it is blank, it will be all 0's. This may not be the same if you are recording an MP3, but you shouldn't be doing that if you are recording professional audio anyway.
  7. Collapse Details
    #7
    Join Date
    Sep 2009
    Location
    Montreal, QC
    Posts
    418
    Default
    Quote Originally Posted by markblasco View Post
    You are correct (on both counts now that I pay closer attention - file sizes and not using MP3s). Recording uncompressed PCM audio will result in silence that takes up exactly as much space as, uh, not silence (?). ;)
    SLR'd WRDS
  8. Collapse Details
    #8
    Senior Member Chadfish's Avatar
    Join Date
    Sep 2005
    Location
    Arcata, CA (Humboldt County!)
    Posts
    2,766
    Default
    That's right Mark. A blank audio file takes up the same space as one with sound. It's only space-saving if the tracks are recorded as discreet mono files. With the H4N you will get a stereo file with one channel having audio. Then you have to go edit that to take the mono side off the stereo file, and make a new mono file. It's not good to blend the 2 channels to do this either, as the "empty" side of the file can have noise. My H4 would record an odd digital sound on the unused track. I would take the file into an audio editor, select the used side of the file, then make a new mono track. Then take that mono track and place it in your timeline.
    And the "settings" depend on the sensitivity of the mic, if you are talking about recording levels. People will try (and rightly so) to steer you to 24 bit recording because at that setting you can record at a much quieter level, and have much less risk of clipping. So the norm is 24 bit / 48k. Going higher will result in more battery drain, as it takes more processing to record at higher sample rates. 16 bit / 44.1 is, I believe what you get in 4 track mode. But you want 48k for video, not 44.1. Why not just buy a good sized card, and record at the proper setting of 24/48? Maybe invest in a preamp too when you get the money. That will help your sound too by getting the signal louder, which lets you turn down the H4N's recording level. That's where your hiss is at - when you use the recorder to pump up the level rather than a mixer.
    Cheers
    Work Examples - Vimeo - My Music
    Sony FS5 :: Panasonic GH4 :: Sony EX1 :: FCPX :: Senn G3 / RodeLink Wireless
    Rode NT1, NTG-2, NTG-3 Shotgun, NT3(Pair), NT4 (Stereo), NT2000, AT4053b Hyper
  9. Collapse Details
    #9
    Admin Luis Caffesse's Avatar
    Join Date
    Mar 2005
    Location
    Austin, Texas
    Posts
    11,077
    Default
    Quote Originally Posted by pmk396 View Post
    Just FYI - to record dual mono on the H4n you have to choose "mono mix" from the INPUT menu while in Stereo Mode, I think.
    I can't remember exactly as I don't have my zoom handy (no pun intended).
    I'm pretty sure everyone is right thought that it won't increase your recording time at all, seeing as you're still recording to both channels.
  10. Collapse Details
    #10
    Senior Member bill totolo's Avatar
    Join Date
    Jun 2007
    Location
    Los Angeles
    Posts
    2,113
    Default
    Quote Originally Posted by Chadfish View Post
    Cheers
    Great info, but I have a couple follow up questions.
    1) Will recording in mono mix mitigate the need to delete a blank track?
    2) If you end up with a blank track is a NLE appropriate to delete the existing blank track? I'd imagine I could put the wav file on a timeline and simply select, and delete the unused track.
    Thanks,
    Bill Totolo
    L.A.
    www.billtotolo.com
Posting Permissions
  • You may not post replies
  • You may not edit your posts
