Results 1 to 9 of 9
  1. Collapse Details
    lens not usable with followfocus - help
    #1
    Junior Member
    Join Date
    Feb 2009
    Posts
    9
    Default
    Hi, I am using a 7D with different lenses. I also have a redrock micro v2 followfocus. My problem is that I can't pull the focus without moving the image. Due to the focus pressing against the lens, the whole camera is moving a bit, but you can see it in the video. When I have a scenario, where I have to change directions of the focus wheel, it moves everywhere.
    How do you guys handle that? I thought about fixing the lens to the rails, but I don't know how and I am not sure if that gets annoying again when changing lenses.
    Please help,
    Axel
  2. Collapse Details
    #2
    Join Date
    Mar 2007
    Location
    Orlando, FL
    Posts
    61
    Default
    Hi Axel,
    Do you have a pic of your setup that you could post to understand what's going on a little better?
    What lens are you having trouble with?
    Do you have the DSLR mount from redrock? If not, you may have to come up with a mount solution to lift the camera and lens up about 2 centimeters. to allow enough room for the follow focus to engage properly. Just throwing this out there, not sure if it is your problem exactly.
    Hope that helps a little bit.
  3. Collapse Details
    #3
    Join Date
    Jul 2003
    Location
    Portland, USA
    Posts
    98
    Default
    Hmmm, I've got a Redrock V2 follow focus as well and the thing is solid as a rock. I've used it with a ton of lenses and have never had any movement of the lens/camera. I'm wondering if your camera is mounted solidly to the rails? The torque of the gear could be moving the camera body.
  4. Collapse Details
    #4
    Junior Member
    Join Date
    Feb 2009
    Posts
    9
    Default
    Hi,
    I will try to attach photos of our setup.
    @betacam2: You got me wrong. I can use the followfocus, there is enough room. I have the vocas lifting thing - so far thats fine. But as soon as I pull the focus, the camera is moving in the opposite direction.
    @yoyodyne: As the 7D only has one screw hole I'd say it is as mounted solid as it can get. Do you also use a rod support with only one screw?
  5. Collapse Details
    #5
    Join Date
    Feb 2010
    Posts
    36
    Default
    I think what you are talking about is that when you focus, the follow focus causes those micro shakes that make it look like you have a cheap tripod. The solution for that would be to get something called a Whip. It connects to the follow focus and allows you to control it from further away, getting rid of the shake that might be transferred from your hands.
    http://store.zacuto.com/zwhip.html
  6. Collapse Details
    #6
    Junior Member
    Join Date
    Feb 2009
    Posts
    9
    Default
    I never used a Whip, but know it and how it works. I guess it will not solve my problem. I already tried different technics of focusing, but as soon as I change direction there is something that causes shakes. Or could it be the tiny play I have with the redrockmicro?
  7. Collapse Details
    #7
    Join Date
    Jul 2003
    Location
    Portland, USA
    Posts
    98
    Default
    Hmmm, how solid is that Vocas camera mount?
    I'm using the Redrock DSLR baseplate and it's very solid. It has the single screw (of course) and a little pin that sticks into the camera body that keeps it from twisting. I cannot move the camera at all when this mount is tightened down.
    Can you wiggle your camera at all when it's mounted?
    Another thing to check for is how hard you have the follow focus gear pressed up against the focus ring gear. You don't want to mash it super tight to the focus ring gear, it should be just tight enough that there is no play. Everything should move real smooth.
    Also changing focus direction should be smooth, their should be no play. Do you get play in the follow focus gearbox itself? You should be able to hold the follow focus in your hand and check for play. Try holding the gear with your fingers and turn the follow focus back and forth, any play or slop?
  8. Collapse Details
    #8
    Junior Member
    Join Date
    Feb 2009
    Posts
    9
    Default
    @yoyodyne
    The vocas doesn't have a pin and when I try to move the camera on the mounted plate I can. But how can I solve that with only one screw whole?
  9. Collapse Details
    #9
    Senior Member
    Join Date
    May 2009
    Location
    Houston
    Posts
    1,148
    Default
    maybe take the FF off and rack focus by hand? Should be pretty smooth as long as your hands arent to shakey.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
