Page 2 of 9 FirstFirst 123456 ... LastLast
Results 11 to 20 of 81
  1. Collapse Details
    #11
    Senior Member
    Join Date
    Sep 2009
    Posts
    1,105
    Default
    Quote Originally Posted by Vitaliy Kiselev View Post
    I tried it on many MTS files, included unpatched ones and on NEX5 footage.
    It either freezed or showed runtimes errors and closed, or showed other strange errors. This is buggy completely unusable software.
    Use the raw avc file, demux from transport stream or container. If you have a transport stream, you can use tsmuxer, if you have a .mov container, use yamb.
    It works fine on 7D, HMC40 files for example.
    It does crash on modded GH1 footage, but not on native GH1 footage. But it doesn't provide as much information on native GH1 footage as it does for other cameras for some reason (it can't read the predicted & residuals)
    What system / OS are you running ?
    I listed it as an option because many codec developers and testers use this tool.
  2. Collapse Details
    #12
    Bronze Member
    Join Date
    Apr 2010
    Posts
    2,415
    Default
    OK, I tried after demuxing on two clips.
    It worked with native 24p and 720p60.
    Information is hard to get really. Interface is also quite strange.
    Stability is non-existant, it just crashes without warning sometimes.
    I want to see tool that help you understand how it works, and this one generally require reverse process :-)
    Anyway it'll be helpful if you can describe info that it shows (manual is also non-existant :-) ).
    Only useful thing that I get from it is that slices number in 1920 mode is simply calculated from MB total number divided on 360.
  3. Collapse Details
    #13
    Senior Member
    Join Date
    Sep 2009
    Posts
    1,105
    Default
    Exactly what kinds of information you're looking for?
    This is a low level stream analyzer that's used usually for software encoder optimization. It's normally used to compare MB pixel info for different streams (e.g. you test a stream with one set of settings , and compare to another). It has PSNR utility, but you need a reference stream (you won't have this with GH1, you would need HD-SDI out and record uncompressed stream to have something to compare to).
    I don't understand all the info it shows , but I know many codec developers use it because it's quite comprehensive. I thought you would understand it all
    The manual is sparse, but you can download it here
    www.h264visa.com/downloads/H264Visa.pdf
    It sounded like you wanted something more advanced than StreamEye, well this is it.
    Anyways, if it doesn't meet your needs or is unstable for you, time to move on and not waste your time
    You can get slice number in StreamEye as well
  4. Collapse Details
    #14
    Bronze Member
    Join Date
    Apr 2010
    Posts
    2,415
    Default
    Quote Originally Posted by PDR View Post
    Yes, this tool just helped me to understand possible reason why we have so many slices in 24n.
    And I am certainly not codec developer despite that I understand some info :-)
    For me TS is also quite important and ability to look at correspondent binary data is also good.
    So, pro tools are much better.
  5. Collapse Details
    #15
    Senior Member
    Join Date
    Sep 2009
    Posts
    1,105
    Default
    It's too bad the manual isn't more comprehensive or explains things more clearly ; they assume the user knows all the basics already (I guess this tool is geared to advanced users)
  6. Collapse Details
    #16
    Senior Member
    Join Date
    Sep 2005
    Location
    Atlanta
    Posts
    345
    Default
    Hey Vitaliy - have you checked this 30-day eval version yet?
    http://www2.tek.com/cmswpt/swdetails...ci=12710&lc=EN
    Maybe it will provide you with enough information to be useful?
    Cameras: Panasonic DVX100A (SOLD 2008) - Panasonic GH1(3) - Panasonic GH3 - Panasonic GH4
    Lenses: Nikon 50mm 1.8 - Pan 7-14mm f4.0 - Pan 12-35mm 2.8 - Leica 25mm 1.8 - Pan 14-140mm
    Audio: Zoom H4n - Sennheiser MKE400 - Audio Technica 4073A - Azden SGM-2X - Countryman Lav, Sennheiser G2
    Mac Pro 8-core (Geekbench 11582), Hackintosh (Geekbench 17569) - gSpeedES - SansDigital Raid 5 - Lacie Biggest 800
    FCP 7 - Adobe CC 2014
  7. Collapse Details
    #17
    Junior Member
    Join Date
    Apr 2010
    Posts
    8
    Default
    What about the Vega Media Analyzers?
    http://www.interrasystems.com/dms/analyzers.php
  8. Collapse Details
    #18
    Bronze Member
    Join Date
    Apr 2010
    Posts
    2,415
    Default
    Quote Originally Posted by e-steve View Post
    Despite file link download is not available.
    It just ask you all contact data and show message that may be you'll be contacted.
  9. Collapse Details
    #19
    Bronze Member
    Join Date
    Apr 2010
    Posts
    2,415
    Default
    Quote Originally Posted by bauhausler View Post
    Request demo, try it, and give me a link to try myself.
  10. Collapse Details
    #20
    Senior Member
    Join Date
    Mar 2010
    Posts
    762
    Default
    You can only analyze built-in demo files though.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
