Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. Collapse Details
    #11
    Senior Member unclebob6958's Avatar
    Join Date
    Jun 2008
    Location
    Greenwich, CT
    Posts
    640
    Cool
    Quite a few years ago Avid acquired Digidesign, the company that makes Pro Tools. M-Audio was acquired by Avid about ten years ago as it's "consumer" audio division (Pro Tools M-Powered). You can run an "ultra-light" version of Pro Tools using M-Audio interfaces, and the M-Audio product line has expanded to include an extensive line of ultra low budget (when compared to PT/HD*) speakers, mics, handheld digital recorders, keyboards, etc.
    M-Audio gear is almost exclusively aimed at musicians, though this has been changing recently.
    * A basic Pro Tools HD system starts at about $15,000, a basic Pro Tools LE system starts at about $1,000, a basic Pro Tools M-Powered system starts at about $120. Before you get too excited PT MP only does 16bit/44.1kHz and currently does not work reliably with QuickTime video files.
    Filmmaking is the art of being invisible; if anyone notices your work you haven't done your job right.
    Peace,
    Bob
    alcoveaudio.com
  2. Collapse Details
    #12
    Senior Member
    Join Date
    Nov 2010
    Posts
    286
    Default
    I came across this thread and wanted to clear up some important misconceptions.
    Quote Originally Posted by DJDecay View Post
    Zoom H4N hands down. - And on top of that, who knows when AVID will finish their acquisitions and recombination and re-branding of all its sub companies.
    In talking about the superior battery life I'd agree or in regard to the quality of the pre-amps, I'd agree that they are certainly a lot less noisy on the Zoom H4N than the MicroTrack II. But the MicroTrack II supports digital (SPDIF coax) input up to 24/96 allowing the use of high end digital microphones such as the Neumann KM 184 D, which include internal conversion and pre-amplification (all at a much higher quality than the pre-amps and converters of any of the recorders discussed in this thread). This has been a feature unique to the MicroTrack II in this size and price range for several years now, and is unavailable with the Zoom H4N, though I'm unsure whether it's been duplicated by other brands in recent years.
    That was the primary reason I chose it for my own use over the Zoom when it launched: to be able to use it with gear that the Zoom did not support at all.
    Quote Originally Posted by unclebob6958 View Post
    Unclebob is closer on this one, but both are fairly off the mark. Avid acquired Digidesign more than a decade and a half ago in 1994 (you can still find clippings about it online courtesy of the Boston Globe among others). Avid acquired M-Audio in 2004. The MicroTrack II came out in 2007, at least 3 years after M-Audio was acquired. It's now 2010 and the M-Audio brand remains fully intact six years after being acquired, lending little credence to DJDecay's caution (or criticism) in this specific instance.
    So far so good. It's mostly accurate, although M-Audio (both then and now) is just as relevant outside Pro Tools environments as within them, previously being one of the lowest-priced solutions for sampling in the early Windows XP GigaStudio days.
    Still pretty on target, although "ultra-light" is a misnomer that appears to be based on misconceptions I'll address later.
    I can't speak comprehensively, only anecdotally on this one, but I can tell you that as of a couple years ago that half the people I talked to that used M-Audio were working in film or TV (including an engineer talking about using multiple Microtrack line units on location for Lost). But that's splitting hairs, really.
    This has all changed since the introduction of Pro Tools 9 and HD Native so users should look up current info., but here are the issues with the information at the time the above post was made.
    The word "system" here refers to several different things but even so, but none of them were entirely accurate. Here's an attempt to standardize and compare.
    We'll use the term "system" to refer to the cost of adding Pro Tools support to a computer rather than buying a full computer with existing Pro Tools support. That means a combination of hardware and software (which is sometimes bundled and sometimes an additional purchase).
    Entry points (as of mid-2010 based on US MSRP, not street price)
    Pro Tools HD: MSRP ca. $11,900 for a system including Digidesign 192 I/O (192 KHz max) or ca. $9,900 for the 96 I/O (96 KHz max), though the latter was already largely absent from the market
    Pro Tools LE: MSRP ca. $899 for Mbox 2 Pro (96 KHz max) and ca. $329 for a system with the Digidesign Mbox 2 Mini (48 KHz max) or $279 with playback only Digidesign Mbox 2 Micro (48 KHz max)
    Pro Tools M-Powered: MSRP ca. $400 for systems using M-Audio Audiophile 2496 (96 KHz), as well as other similarly priced offerings.
    So, going by the MSRP, LE was cheaper at that point if you wanted to work at 48 KHz or below than M-Powered, M-Powered provided the cheapest 96 KHz option and HD was still consistently more expensive than either one by thousands of dollars. The largest part of the price for the M-Powered systems mentioned above was the price of buying Pro Tools M-Powered, which was not typically bundled with the interfaces (unlike LE or HD).
    At the time of the referenced post, running Pro Tools HD 8 required two pieces of hardware: a card to run the software (that came bundled with Pro Tools HD software) and additionally an audio interface. Let's assume the post was not concerned with buying significantly older hardware since much of it is no longer compatible.
    The cheapest Pro Tools HD card and software bundle was the Pro Tools HD1 Core System. (Sold for $7995 at the time of referenced post).
    The cheapest Pro Tools HD audio interface was the Digidesign 96 I/O (MSRP $1995.00) which supported 96 KHz, but the cheapest "current" interface was the Digidesign 192 I/O (MSRP $3995) and the 96 I/O has been phased out.
    Even assuming that UncleBob6958 was referring to the Digidesign 192 I/O (as opposed to the 96 I/O) that adds up to $11,900, which is still roughly 20% less than the price originally quoted as the entry level (and the difference is even more pronounced if we include the 96 I/O).
    A quick glance at the official product page below can confirm that no such limitation is built into the software.
    http://www.m-audio.com/products/en_u...MPowered8.html
    The "ultra-light" versions of Pro Tools were actually called "Pro Tools M-Powered Essential" and "Pro Tools SE", both of which had far more limitations than either LE or M-Powered. The primary differences between Pro Tools LE 8 and M-Powered 8 (other than hardware support) had to do with what add-ons you could get, but the software itself maxed out at 24-bit, 96 KHz recording (unlike 192 KHz with HD) but was more often limited by hardware than software. LE supported more first-party add-ons, including the ability to max out at a higher track count than with the add-ons for M-Powered, but if you were only comparing the two pieces of software (without add-ons) LE and M-Powered were essentially equivalent. I can tell you that from thousands of hours of shuttling between M-Powered, LE and HD systems, though more of that time was spent in version 7 than 8 as well as having gone through the official documentation several times. The distinction between LE and M-Powered is obsolete as of Pro Tools 9.
    I've used a variety of audio interfaces, converters and recorders and I always think it's important for people to accurately understand the distinctions rather than paying for hardware they don't need. It used to be (with the Mbox 1) that you payed more for low sample-rate LE combo (with some of the worst converters in the industry as can be seen on real-world ADC/DAC graphs) than the entry level contemporary M-Audio Audiophile 2496 and a copy of M-Powered. The 2496 was already cheaper and decreased in cost to only a fraction of the price if you didn't need to buy Pro Tools M-Powered to go with it, an option you didn't have with the MBox. Things are a bit more balanced now, but you still tend to get better converters at the same price point with the M-Audio line than the Digidesign one (as well as better support for non-Pro Tools software).
    As an example, the $1,295+ MSRP of the Digi 003 Rack (LE interface) still didn't make it easy to use most of the inputs and outputs outside of Pro Tools, so on one project we installed an M-Audio Audiophile 2496 mainly to be able to monitor SPDIF output under other OS X applications (even though the Digi 003 already has easy to use SPDIF within Pro Tools).
    That said all of the Pro Tools talk has been rendered largely obsolete by the changes to software and hardware introduced in the last few months, including cheaper HD options and the consolidation of LE and M-Powered into a single product line with Pro Tools 9, which is no longer limited to audio interfaces by Avid-owned companies. However, the older hardware and gear is still around, so the points were worth clarifying.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
