Page 2 of 34 FirstFirst 12345612 ... LastLast
Results 11 to 20 of 331
  1. Collapse Details
    #11
    Senior Member
    Join Date
    Jul 2009
    Posts
    378
    Default
    hey guys i tried the 720 24p avchd patch today, for some reason what im recording has a view that is 2x zoomed (so a 50mm becomes 100mm)//anyone else has this?
  2. Collapse Details
    #12
    Senior Member
    Join Date
    May 2009
    Posts
    124
    Default
    If anyone wants to speed-test their SD card, I found this great utility:
    Crystal Disk Mark --
    http://crystalmark.info/software/Cry...k/index-e.html
    It runs a series of read/write tests against the card and reports the MB/s average. This assumes, of course, you have a good high-speed SD card reader...
  3. Collapse Details
    #13
    Senior Member
    Join Date
    Dec 2005
    Location
    Florida
    Posts
    3,224
    Default
    Quote Originally Posted by sammysammy View Post
    Double check to make sure zoom wasnt enabled in the settings. there's a 2x and a 4x.
  4. Collapse Details
    #14
    Senior Member
    Join Date
    Jul 2009
    Posts
    378
    Default
    pretty sure it wasnt , i think also Nurbs said today he had this same issue ..tester just posted this "Yeah, 720p23,97 AVCHD is clipped from full 1920 picture, must be fixed later:-)
    But best thing that we can play this progressive 24fps footage in camera without problems" ..i guess its recorded with 2x ratio at 720 24p ,at least for now..
  5. Collapse Details
    #15
    Senior Member
    Join Date
    Dec 2005
    Location
    Florida
    Posts
    3,224
    Default
    Yep, I read that shortly after I read this.
  6. Collapse Details
    #16
    Senior Member matt s.'s Avatar
    Join Date
    Jun 2005
    Location
    Waynesboro, PA
    Posts
    1,563
    Default
    Isn't 24 Mbps the highest bit rate for all avchd? How can you have 32/34Mbps?
  7. Collapse Details
    #17
    Bronze Member
    Join Date
    Apr 2010
    Posts
    2,415
    Default
    Quote Originally Posted by matt s. View Post
    It is AVCHD standard rate.
    It means that any device will play it fine at 24Mbps (5.1 high profile, as far as I remember), nothing else.
  8. Collapse Details
    Jobless, these settings are goooood!
    #18
    Senior Member
    Join Date
    Sep 2009
    Posts
    344
    Default
    Quote Originally Posted by jobless View Post
    I tried with this settings and it's working.
    I record 4 minutes long clip ( I stopped the camera)
    Video buffer 40.000.000
    Video bitrate adjustment 40000000
    Overall bitrate adjustment 46000000
    Limiting bitrate adjustment 50000000
    Overall bit rate : 34.8 Mbps
    Maximum Overall bit rate : 46.0 Mbps
    Does the native 24/25p playback in-camera?
  9. Collapse Details
    #19
    Senior Member jobless's Avatar
    Join Date
    Feb 2010
    Location
    London, U.K.
    Posts
    143
    Default
    Quote Originally Posted by Adventsam View Post
    No, it doesn't...
  10. Collapse Details
    #20
    Senior Member
    Join Date
    Feb 2010
    Posts
    908
    Default
    does the AVC bitrate adjustment work without the "native 24p" setting? I still need to view my files in camera or on a monitor after I shoot them.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
