Page 2 of 306 FirstFirst 1234561252102 ... LastLast
Results 11 to 20 of 3054
  1. Collapse Details
    #11
    Senior Member
    Join Date
    Mar 2009
    Location
    Kowloon, Hong Kong SAR
    Posts
    797
    Default
    +1 if this is for real. I'm after bitratess going up.
  2. Collapse Details
    #12
    Senior Member
    Join Date
    Feb 2010
    Posts
    908
    Default
    I'm a GH1 user but I don't have time to offload firmware and decrypt. Do you have the decrypted FW posted somewhere so we(I) can take a look?
  3. Collapse Details
    #13
    Bronze Member
    Join Date
    Apr 2010
    Posts
    2,415
    Default
    Legally I can't distribute GH1 firmware.
  4. Collapse Details
    #14
    Senior Member
    Join Date
    Jul 2009
    Posts
    1,315
    Default
    if you are able to see 60 50 25 and 24 fps does that mean it is possible to unlock those fps for user use? very interesting. I know that when the camera is put together the main board allows the assembler to set region only once then it is locked. can explain why some people get their camera serviced and returned with different region settings if the main board is changed.
  5. Collapse Details
    #15
    Bronze Member
    Join Date
    Apr 2010
    Posts
    2,415
    Default
    Yes it'll be possible.
    Don't know about region locking other then that it is purely artifical thing for long time.
    I believe that 720p 24fps is very interesting indeed.
    And if bitrate could be up to 28Mbps, picture will be fantastic.
  6. Collapse Details
    #16
    Senior Member
    Join Date
    Feb 2010
    Posts
    908
    Default
    If you don't seconds time even to download file, how you could spend hours for research?
    Cause as I sit at my desk at work, I can sift through code, but I can't have my camera sitting there looking suspiciously like I'm not doing work..
  7. Collapse Details
    #17
    Bronze Member
    Join Date
    Apr 2010
    Posts
    2,415
    Default
    Quote Originally Posted by TrueIndigo View Post
    Sorry for going off topic, but could you briefly say if your work on the Pentax camera(s) uncovered any possible enhancements for their video capability -- such as bitrate changes or 24/25 fps frames rates? Are they easier to work on compared to Panasonic?
    I didn't worked on K7 as I don't have one. I am also not interested in K7 video features as it uses sensor not suitable for video. If anyone want to work on AGC it is not that hard as we have all the tools and instructions can be found in my blog or site pages.
    Samsung and Pentax use Fujitsu FR cores and this is a RISC processor.
    Most notably it means interleaved code and data and heavy usage of offsets that must be processed by hand. Processor module that we made are also not very good.
  8. Collapse Details
    #18
    Senior Member alignment1's Avatar
    Join Date
    Jan 2008
    Location
    CT
    Posts
    759
    Default
    I know very little about code, but --Any chance for more than 60fps??
    now that I type this- it's probably no--oh well tossed it there.
    Definitely take the higher bitrate though!!!
    Zack - Alignment Productions
    BLOG
    VIMEO
    Panasonic GH-13 / Lumix 7-14mm f4 / Lumix 14-140mm f4 / Vivitar 24mm f2 / Canon FD 28mm f2.8 / Tokina SD 28-70mm f3.5 / Canon FD 50mm f1.4 / MBP 2.66GHz Intel Core i7, 4GB RAM / MACPRO quad 2.7GHz, 8GB RAM / Twin 23" LCD's / FCS2 / AECS4 / Atari 2600
  9. Collapse Details
    #19
    Senior Member Oetam's Avatar
    Join Date
    Sep 2009
    Location
    Amsterdam
    Posts
    119
    Default
    A big issue for us PAL users is the 30min. time limit maybe you could check on that.
    Also, I have the 1.2 firmware Panny released first that allows 3rd party batteries, maybe you could use the code from that version so you have the 1.2 features + 3rd party battery compatibility.
    here is the link: http://www.sendspace.com/file/aw0cwo
  10. Collapse Details
    #20
    Senior Member
    Join Date
    Mar 2008
    Location
    N.Y.C.
    Posts
    2,832
    Default
    MJPEG 24 FPS and higher bitrate for it and AVCHD would be fantastic. I would definitely pay for that. I have absolutely no knowledge on how to work with coding. Good luck with the project and thanks for the effort.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
