Page 101 of 306 FirstFirst ... 5191979899100101102103104105111151201 ... LastLast
Results 1,001 to 1,010 of 3054
  1. Collapse Details
    Senior Member ryancglover's Avatar
    Join Date
    Aug 2008
    Location
    Toronto, ON
    Posts
    287
    Default
    Quote Originally Posted by NURBS View Post
    Testing new ptool ver.
    Change only this mode.
    VA 1920 frame height: 1080 -- change to --> 820 (result. camera can't record video and show text message: NO ADDITIONAL SELECTIONS CAN BE MADE).
    VA 1920 frame height: 1080 -- change to --> 1180 (result. camera can't record video and show text message: NO ADDITIONAL SELECTIONS CAN BE MADE).
    Testing more.
    Quote Originally Posted by tester13 View Post
    Try to use 816, not 820.
    Anyway it looks we'll need to adjust this.
    If it becomes possible to shoot (and monitor on the LCD?) 4:3 @ 1920x1440 and 1.2:1 @ 1920x1600 my head will explode.. that'd be so perfect for scope shooting!
    ryancglover.com - filmmaker, cinematographer
    HILLS GREEN - a feature film. USER FILMS thread.
    yellyfish films
  2. Collapse Details
    Bronze Member
    Join Date
    Apr 2010
    Posts
    2,415
    Default
    Ptool Updated (without version change)
    Modified 1920 frame height patch (try to use 816 or 8 multiples), as both used numbers was wrong.
    Also Bitrate Adjustment 3 completely changed, as we need to test how encoder perform under lowered bitrate, so set it to about 10.000.000 or even 6.000.000. I need such movies uploaded to analyze them at low level.
  3. Collapse Details
    Default
    This is getting a little confusing. Should we test Bitrate Adjustment 3 while also changing the values of Bitrate Adjustment 1 and 2 or leave them at default? And what about "VA Bitrate Top Limit", etc.?
  4. Collapse Details
    Bronze Member
    Join Date
    Apr 2010
    Posts
    2,415
    Default
    Quote Originally Posted by billy fattey View Post
    Only this setting (VA Bitarete Adjustment 3) must be changed, and by lowering it, not upping. As described.
    Do not touch anything else.
  5. Collapse Details
    Default
    VA BITRATE ADJUSTMENT 3: 6000000
    http://dl.dropbox.com/u/216574/00001.MTS
    VA BITRATE ADJUSTMENT 3: 10000000
    http://dl.dropbox.com/u/216574/00002.MTS
    VA BITRATE ADJUSTMENT 3: 16000000 (default)
    http://dl.dropbox.com/u/216574/00003.MTS
    VA BITRATE ADJUSTMENT 3: 3000000
    http://dl.dropbox.com/u/216574/00004.MTS
    That last one is interesting in that it reduced the file size to 4.6MB where the other clips hover around 9MB. All clips are a 10 second static shot at same exposure. NTSC FHD 1080p.
    http://dl.dropbox.com/u/216574/00005.MTS
  6. Collapse Details
    Default
    I also tried to set VA BITRATE ADJUSTMENT 3 to 20000000 and 24000000, but the camera froze on each and wasn't able to record.
  7. Collapse Details
    Bronze Member
    Join Date
    Apr 2010
    Posts
    2,415
    Default
    Thanks, very useful, very.
    16000000 file seems to be wrong.
    If you can, try to do same things using 720 mode in maximum quality.
    Also more graduated change between 6000000 and 1000000 is useful.
  8. Collapse Details
    Senior Member
    Join Date
    Apr 2008
    Location
    West Country, UK
    Posts
    411
    Default
    tester13: "It is hard to do anything with this hardware and such restrictions.
    Best thing is to introduce 1080 film mode that removes all AVCHD restrictions and uses maximum possible bitrate." -- does this mean the only way forward for a good mod is to concentrate on the MJPEG mode? Or can AVCHD be sufficiently modded on here to be worthwhile in 1080p mode.
  9. Collapse Details
    Bronze Member
    Join Date
    Apr 2010
    Posts
    2,415
    Default
    It means that you must clearly say customers that clips recoded in film mode won't play in some AVCHD players.
    It is better try to adjust AVCHD.
    720p30 MJPEG is already near its limit.
  10. Collapse Details
    Senior Member
    Join Date
    Feb 2010
    Posts
    908
    Default
    It's interesting to point out that a number of the "pro" digital cinema cameras record to JPEG. Cameras like the Vipre do JPEG(2k) at 23.98 as their primary capture with little other choices.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
