Page 1 of 11 12345 ... LastLast
Results 1 to 10 of 103
  1. Collapse Details
    Home made Kino Part 1
    #1
    Zoomforce
    Guest
    Default
  2. Collapse Details
    Re: Home made Kino Part 1
    #2
    Senior Member
    Join Date
    Dec 2003
    Location
    Lake Constance, Germany
    Posts
    178
    Default
    any problems with flicker or noise?
    I like your setup, looks very neat,
    how much were the parts?
  3. Collapse Details
    #3
    Guest
    Guest
    Default
    Ohh,
    That looks sweet!
    Very good design. Is that a Matthews baby plate? What a great idea!
    More pics! (If possible. I know you're busy, so it's greatly appreciated).
    By the way, I found the GE bulbs that one of the production studios uses in place of the Kino Flos. I found it at a LAMPS PLUS in town. They're the GE F40SPX35 bulbs. They're T12 bulbs and they are rated at 3500 Kelvin with a CRI of 93 (I believe). The GE F40SPX30 is 3000 K, but I've heard the 3500K renders indoor lighting better. Am I making any sense or am I just rambling. ;D
  4. Collapse Details
    #4
    Zoomforce
    Guest
    Default
    Total cost was about $50US.
    Thats an Avenger baby plate. Hands down, on ever item I have seen, Avenger makes better stuff than Matthews.
    No Flicker and no noise.. due to the Electronic Ballast. The first identical light I made a few weeks ago I shot with for 12 hours and it worked fantastic.
  5. Collapse Details
    #5
    Guest
    Guest
    Default
    Great work.
    Avenger baby plate. Sounds good. I'll look them up. Thanks!
    By the way, do you put the light on a regular light stand? Which stand? Is it top heavy? Do you have a pic of the light mounted to the stand?
  6. Collapse Details
    #6
    Default
    With a plate like that you'd have to use a stand with a rotating grip head. Otherwise you couldn't tilt the light into position.
  7. Collapse Details
    #7
    Senior Member Rogue Crew's Avatar
    Join Date
    Nov 2003
    Location
    Princeton, NJ
    Posts
    343
    Default
    Jarred, that looks sweet! Quick questions. Did you line the reflector trough with foil? The trough looks like its supposed to have ends on it - did you leave them off on purpose? Why the tape?
  8. Collapse Details
    #8
    Zoomforce
    Guest
    Default
    tape is to knock down any reflections from other light sources.
    There was no ends, thats the way it came.
    And no foil, the white gloss does a pretty good job of bouncing by itself.
  9. Collapse Details
    #9
    Zoomforce
    Guest
    Default
    [quote author=Barry_Green link=board=lighting;num=1092848834;start=0#5 date=08/24/04 at 16:22:31]With a plate like that you'd have to use a stand with a rotating grip head. *Otherwise you couldn't tilt the light into position.[/quote]
    if you didnt have a c stand, you can use a regular stand with a gobo/knuckle grip head. I use it on a Cstand with a gobo arm for the most flexibility.
  10. Collapse Details
    #10
    Bronze Member
    Join Date
    Jun 2004
    Location
    Springfield, USA
    Posts
    511
    Default
    Awesome Idea, I've thought about doing that before. How many degrees kelvin are those phillips bulbs? I'd like to know what the footcandles or lux is about 9 or 10 feet away.
    I bet someone that has a machine shop could take those parts and make a large square soft light that's like ten bulbs accross.
    Why are Kino's so goddam expensive?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
