Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. Collapse Details
    Building a 35 foot crane?
    #1
    Senior Member johnhafner's Avatar
    Join Date
    Sep 2009
    Location
    Los Angeles, CA
    Posts
    104
    Default
    I'm DP for an upcoming no-budget ($300 total) 7 min short where it calls for a birdseye view as high as possible. I'm shooting on my Canon 7d and since it weighs less than 4 pounds with the lens I got the crazy idea of build a TALL crane or other type of support and hoisting it up real high.
    I'm considering building a 35 foot crane out of two aluminium ladders bolted together and steel cable I have laying around. Is this totally insane or has anyone done something like this? [Yes I know it's prob not the safest thing. I wouldn't let anyone get near it but me till I load and wind tested it before hand. Renting a jib or anything more that $100/day enough is out of the question.]
    I also considered building a tower with 4 support beam made of 3X 10'pvc pipes each. Also crazy I know. If anyone has any other ideas let me kniw
    Oh, and the shot should twirl downward and end up in a close up on the talents upturned face. Gotta love these writers.
    Has anyone built or bought a cage or other support type system I could dangle the camera on? I've got a few shots in another project I'm directing I would like to run a cable and have the camera glide down it but I have no idea if this is even worth my effort.
  2. Collapse Details
    #2
    Default
    Quote Originally Posted by johnhafner View Post
    I think you are going to have to tell the writer that this shot is not absolutely needed to move the story forward. It is a cinemagraphic technique to be sure, but ultimately, for your budget undoable safely, and beyond persona/camera safety, not guarenteed to get the effect you seem to be wanting, since it apparently involves camera motion and change of position.
    So, ot only do you have positioning and pointing issues, you have 'motion control' issues.
    For some shots, still shots, I have gotten on top of a 18' ladder, Hasselblad in hand, with people stabilizing the ladder, and shot down on the subject. However, this is only a last resort.
  3. Collapse Details
    #3
    Senior Member
    Join Date
    Feb 2007
    Location
    NE Ohio
    Posts
    253
    Default
    This just has bad idea all over it. Just loose the shot and move on.
  4. Collapse Details
    #4
    Senior Member clang's Avatar
    Join Date
    Jun 2007
    Location
    New Zealand
    Posts
    1,124
    Default
    On a $300 budget, forget any fancy shots like this. (On a $30 million budget, it would be fine )
    A handmade 35 foot crane is very likely to result in someone or something falling 35 feet, possibly hitting someone or something as it lands. Seriously.
    Talk to the director about a more practical shot that still meets the film's needs - if the script doesn't work without such a fancy show-off shot, then it's a crap script.
  5. Collapse Details
    #5
    Default
    If you're thinking about building a tower, just rent scaffolding. It's surprisingly cheap and sounds a lot safer than anything else.
  6. Collapse Details
    #6
    Senior Member
    Join Date
    Sep 2008
    Location
    uk
    Posts
    243
    Default
    all sounds very dangerous...how about finding a footbridge or similar that the talent can walk under (make sure everything has a safety cable or similar attached).
  7. Collapse Details
    #7
    Senior Member Chris Santucci's Avatar
    Join Date
    Feb 2006
    Location
    Buffalo, New York
    Posts
    1,903
    Default
    Yeah, a wind or some sudden imbalance could mean a major bummer for everyone involved.
  8. Collapse Details
    #8
    Senior Member Zblock's Avatar
    Join Date
    Nov 2009
    Location
    Hollywood
    Posts
    814
    Default
    Although not the smoothest movement, you could rent a man lift to get you as high as you need and then lower you. I think the beginning movement would jolt but the high to low transition should be smooth enough to get a good shot.
    Actor/Filmmaker
    Pre-Production on 3rd full length
    HVX200a
    Sgblade 35mm adapter
    Pentax Lenses
    http://www.imdb.com/name/nm2885419/
    www.fathomsdeepmovie.com
    www.kavadba.com/entertainment.html
    www.facebook.com/fathomsdeep
    www.elevatedclothingco.com
  9. Collapse Details
    #9
    Join Date
    Feb 2006
    Location
    Buffalo, New York
    Posts
    1,903
    Default
    Yeah, a Genie Lift is an option. I've used these and they're pretty stable and cheap to rent.
    http://genielift.com/ss-series/ss-1-1.asp
  10. Collapse Details
    #10
    Default
    And remember that if the movement needs to end at a specific shot, it might be better to shoot it backwards, starting at the desired "end shot", and then lift the camera on a cable and let it turn as it goes up (which it will do naturally unless you stop it.) Of course, it is trivial to reverse the direction of the video clip in any NLE.
    Recording audio without metering and monitoring is exactly like framing and focusing without looking at the viewfinder.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
