a bit more conclusive
cheers,
mike
Results 1 to 7 of 7
Senior Member
- Join Date
- May 2009
- Location
- nyc
- Posts
- 180
10-08-2009 04:12 PM
10-08-2009 07:26 PM
did you have IS turned on with the lenses? looked super jittery like it was stepping thru the pan.
Senior Member
- Join Date
- May 2009
- Location
- nyc
- Posts
- 180
10-08-2009 07:33 PM
no IS. the wind was crazy strong on the roof when I shot it
10-09-2009 04:56 PM
Wow, I'm so glad someone did this test properly!
Thanks!
America is truly a nation of scientific geniuses!!!!
So what's your conclusion Mike??
10-09-2009 05:00 PM
The 7D does appear to be slightly better than the 5D at 1080p30.
Current cameras: Panasonic LUMIX DMC-GH2 | Sony HDR-SR11 (infrared modded)
10-09-2009 06:16 PM
Great test. Looks fairly identical to me.
The jitter looks like something went wrong with the 24p conversion. Good example of a pulldown error. The same jitter that happens when you drop a 30p sample into a 24p timeline.
Senior Member
- Join Date
- May 2009
- Location
- nyc
- Posts
- 180
10-10-2009 04:27 AM
thanks guys. would hardly call that genius. lol. but thanks. pretty close, almost identical. I certainly would not worry about it, was just curious if there is a difference at all btw the two, for my type of shooting not a problem at all (I had no problem using the D90 either, which has the worst rolling shutter of all). If rapid movements are a must, gotta go with a CCD sensor.
Rolling Shutter 7D, 5D at identical panning speed
