Results 1 to 9 of 9
  1. Collapse Details
    Camera and salt spray, best way to clean?
    #1
    Senior Member Capt Quirk's Avatar
    Join Date
    Aug 2006
    Location
    Tennile Ga
    Posts
    5,136
    Default
    Yeah, the title is pretty explanatory. I was out on a fishing boat for 20 some hours, and while it didn't take any direct hits, we did get a lot of spray. I had the lens on the entire time we were on the boat, so only the outside of the camera was exposed. How should I clean it to prevent problems down the road?
  2. Collapse Details
    #2
    Join Date
    Aug 2006
    Location
    Tennile Ga
    Posts
    5,136
    Default
    Well? Any ideas before it rusts?
  3. Collapse Details
    #3
    Default
    Don't potatoes absorb sodium? You could slice some up, rub them up and down your camera, and then fry 'em up and enjoy a snack.
  4. Collapse Details
    #4
    Join Date
    Aug 2006
    Location
    Tennile Ga
    Posts
    5,136
    Default
    Ok... any other ideas that don't involve getting vegetable juices on the camera?
  5. Collapse Details
    #5
    Default
    I was under the impression you were seeking an alternative to taking a rag to it asap.
  6. Collapse Details
    #6
    Join Date
    Aug 2006
    Location
    Tennile Ga
    Posts
    5,136
    Default
    Wiped it with a clean cloth, but wasn't sure about using household chemicals. I also wasn't sure if a dry cloth was enough.
  7. Collapse Details
    #7
    Default
    How do you know spray did not enter the interior? If you're relying on this cam for work you should get it checked. Even if it was just the outside, a dry cloth isn't going to remove all of the salt. Second to taking it to a pro, I would wipe it down with damp cloths, going one way and only one time, with each cloth only being used for one wipe to avoid spreading the salt.
  8. Collapse Details
    #8
    Join Date
    Aug 2006
    Location
    Tennile Ga
    Posts
    5,136
    Default
    Considering the quality of care I got from JVC the last time, I would rather hire a crackhead to service it.
  9. Collapse Details
    #9
    Default
    Sandy prefers Panny but is willing to take a look.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
