Page 1 of 2 12 LastLast
Results 1 to 10 of 17
  1. Collapse Details
    budget follow focus/zoom gear for stock and c-mounts??
    #1
    Default
    I'm looking to adapt my c-mount primes and the stock zoom on a GH1 to my follow focus. If I'm not mistaken it's a .8 (?) gear (cavision).
    THIS looks perfect for some of my short throw helicoids and possibly the GH1 stock. But damn that's expensive for a little plasic gear strip and screw lock!
    What's the advice for these 35-44 MM dia. 16mm cine c-mounts? and what would you use for the GH1 stock zoom? There has to be a $50ish solution out there!
    TIA
    ________________________________________
    you may know me as:MILapse
  2. Collapse Details
    #2
    Senior Member Ben_B's Avatar
    Join Date
    Nov 2008
    Location
    Berkeley, CA
    Posts
    3,557
    Default
    If you find some way to attached the ends and tighten DIY then the zip itself is only $12.
    Leave it to Zacuto to sell the thing you want for $12 but a tiny piece of metal that you need to make it work for an extra $130.
    http://store.zacuto.com/zip-gear-replacement.html
  3. Collapse Details
    #3
    Join Date
    Nov 2008
    Location
    Berkeley, CA
    Posts
    3,557
    Default
    http://www.indifocus.com/products_indifocuspro.htm
    Replacement cine pitch gear 0.8...$22? That work?
  4. Collapse Details
    that's not the one you want...
    #4
    Senior Member nickybee's Avatar
    Join Date
    Sep 2004
    Location
    Los Angeles
    Posts
    179
    Default
    if you want the zip gears - then use these...
    http://www.indifocus.com/products_indifocus20.htm
    (look at bottom of page) - way cheaper than zacuto...
  5. Collapse Details
    #5
    Senior Member Martti Ekstrand's Avatar
    Join Date
    May 2009
    Location
    Deep, deep in PAL land.
    Posts
    1,631
    Default
    This is the most inexpensive follow focus I've seen on the intartubes so far
    http://www.designbydave.net/dfocus/index.html
  6. Collapse Details
  7. Collapse Details
    #7
    Default
    Thanks all. I may try to make my own connection with the gear strip. A zip tie doesn't inspire confidence!
    Quote Originally Posted by Psynema View Post
    My hand is free
    Free focus puller! Nice. I'll tell you where to be and when...
  8. Collapse Details
    #8
    Join Date
    Nov 2008
    Location
    Berkeley, CA
    Posts
    3,557
    Default
    Quote Originally Posted by Martti Ekstrand View Post
    I was sorely tempted by this, but then I saw the way it shakes right as he pulls focus in the sample video...maybe he just had a bad tripod?
    I was planning on building my own...but the cost of that would probably be pushing up into $100 range anyway and might not even be as nice as this one.
  9. Collapse Details
    #9
    Senior Member j's Avatar
    Join Date
    Jan 2004
    Location
    NorCal, USA
    Posts
    2,166
    Default
    Well, for $100 you can't complain too much. It's certainly better than anything I could DIY by throwing $100 at...
    I just find it amusing how they saved money on market research on the brand image. I mean the name alone: "defocus" It doesn't give me much confidence.
  10. Collapse Details
    #10
    Join Date
    Nov 2008
    Location
    Berkeley, CA
    Posts
    3,557
    Default
    Also looking at Indifocus20...it's $150 but comes with the zip rings and the marking board that are extra on the D|Focus.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
