Results 1 to 7 of 7
  1. Collapse Details
    Ge reveal bulbs color temp?
    #1
    Default
    Does anyone know what color temperature GE reveal bulbs are? Are they closer to 3200K or 5600K? Any issues with using them and mixing them with pro lights?
    Thanks!
    What do you mean funny? Like a clown? Do I amuse you?! Huh??!!
  2. Collapse Details
    #2
    Senior Member
    Join Date
    Dec 2004
    Location
    Lafayette, LA
    Posts
    299
    Default
    I have found the daylight temperature CFL bulbs are much closer than the "reveal" bulbs, which were not close enough to work.
    They're cheap enough to get a few different wattages to tune in a light to your taste (since all but the most expensive don't work on a dimmer.)
    Plus you can get more light out of a practical if needed, they can put out the light of a 200 watt bulb for less than 60 watts, which may be the max rating of the lamp.
  3. Collapse Details
    #3
    Supporting Member Taylor Rudd's Avatar
    Join Date
    Aug 1984
    Location
    Austin, TX
    Posts
    1,372
    Default
    This is in no way scientific, but I feel like they fall near the middle (roughly equivalent to Tungsten with ~1/2 CTB). I bought them to use as practicals in a short I did in December.
    I was balanced to daylight, but wanted the practicals to still have a slight-tungsten glow. They worked perfectly. Plus they work better than CFL with my dimmers
  4. Collapse Details
    #4
    Default
    I white balanced on a regular bulb and got 2600
    I white balanced with the GE reveal bulb and got 2800
    They are definitely cooler, but not by a lot (if my test was accurate).
  5. Collapse Details
    #5
    DVXuser Sponsor Cool Lights's Avatar
    Join Date
    Apr 2006
    Location
    Shenzhen, China
    Posts
    2,517
    Default
    On the web, several sources quote GE as saying its 2850K so that's consistent with your testing.
    Richard Andrewski - Cool Lights USA - Site Sponsor
    Epic X #2392 - Skype "coolvideolights"
  6. Collapse Details
    #6
    Junior Member
    Join Date
    Mar 2009
    Posts
    2
    Default
    n:Vision, makers of compact bulbs, has a huge line of bulbs of varying "Watts" BUT whats more important is they give out all the specs including COLOR TEMP. The one downside is they are a Home Depot exclusive so if you only have a Lowes in your town you are out of luck.
    http://www.homedepot.com/webapp/wcs/...0053&langId=-1
  7. Collapse Details
    #7
    Senior Member Chris Light's Avatar
    Join Date
    May 2008
    Location
    Fallbrook, CA
    Posts
    2,076
    Default
    if your town doesn't have a Lowes, it sure as beans doesn't have a Home Depot. think Walgreens, Longs, CVS, Rite Aid. all on the same block haha
Posting Permissions
  • You may not post replies
  • You may not edit your posts
