Thread: monitor vs tv
Results 1 to 4 of 4
  1. Collapse Details
    monitor vs tv
    #1
    Senior Member
    Join Date
    Aug 2004
    Location
    Hollywood, USA
    Posts
    730
    Default
    With HD monitors costing 2/3 and up as much as the camera it seems crazy to spend so much on a monitor. Opinions? Has anyone found an HDTV or maybe even a computer monitor with a HDMI connector that works well for the field?
  2. Collapse Details
    #2
    Deals in Lead PerroneFord's Avatar
    Join Date
    Nov 2006
    Location
    North Florida
    Posts
    4,524
    Default
    What is it you want the monitor to do for you?
    Establish critical focus?
    Check depth of field?
    Show tonal range?
    Verify colors?
    Show accurate lighting ratios?
    If you are just monitoring to check focus, composition, and basic lighting, then just use what you've got. I monitor with SD for those purposes. But if you need a calibrated monitor for accurate color and so forth, then you're in the big leagues and you're going to have to play with the big boys.
    Don't be a BillyBob...
  3. Collapse Details
    #3
    Senior Member Hidef1080's Avatar
    Join Date
    Sep 2008
    Location
    Atlanta, Ga.
    Posts
    666
    Default
    I use a Gateway HD computer monitor [1920 x 1200] which has HDMI.
    I used it to "set the setting" on my camera and I have to say that it helped me better than using the camera's LCD or shooting clips and then making adjustments.
    Calibrating the monitor helped much...
    I've never used a true Pro HD monitor so I don't know how much I could gain from it.
    D600, 7D | CS-6 | Dell m6500 - Windows 7 Pro 64bit
  4. Collapse Details
    #4
    Senior Member
    Join Date
    Aug 2004
    Location
    Hollywood, USA
    Posts
    730
    Default
    I use monitors mostly for producers and clients. I have a sony sd monitor that I can continute to use. I do like the small lightweight lcd monitors.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
