Page 1 of 2 12 LastLast
Results 1 to 10 of 17
  1. Collapse Details
    Letus extreme edge to edge Sharpness
    #1
    Member balster's Avatar
    Join Date
    Feb 2008
    Location
    Amsterdam, The Netherlands
    Posts
    98
    Default
    I am using the Letus Extreme with the custom EX1 achromat and just did some sharpness testing. I used one of my Carl Zeiss lenses, a 85mm with Nikon fitting. Great lenses by the way. Edge to edge looks good but I am not quite satisfied. Namely the right side of the screen makes me think because it won't focus with the rest of the screen. I would guess it's a ground glass issue. Any thoughts?
    You can check the fullscreen image on my blog http://blog.s106.com
  2. Collapse Details
    #2
    Senior Member
    Join Date
    Feb 2008
    Posts
    857
    Default
    I have the exact problem. The right side is a little soft. In addition, the GG shifted towards the right side more. Anyone else has any other suggestion?
  3. Collapse Details
    #3
    Senior Member
    Join Date
    Jul 2007
    Posts
    437
    Default
    On a side note, how did you accomplish the effects in the s106 Showreel? It's a very nice effect.
  4. Collapse Details
    #4
    Join Date
    Feb 2008
    Location
    Posts
    98
    Default
    hi myCharlie,
    in response to your side note... wich effects do you mean?
    back to subject;
    anybody tried anything with the ground glass?
    Happy shooting with the Panasonic HPX300 and P+S Technik Mini35c. Check my blog for my insights on this great combo. http://blog.s106.com/
  5. Collapse Details
    #5
    Director of Photography TimurCivan's Avatar
    Join Date
    Aug 2004
    Location
    New York City
    Posts
    12,182
    Default
    is that purple fringe EX1 native, Zeiss native, or LEX native?
    Cinematographer
    Sigma Pro
    www.timurcivan.com 917-589-4424
  6. Collapse Details
    #6
    Filmmaker's Mod
    Join Date
    Dec 2005
    Posts
    17,389
    Default
    That fringe is nasty to deaf. Seconding Timur's inquiry.
    Comet Color Page
    Allow me: fanboy of great images.
  7. Collapse Details
    #7
    Join Date
    Jun 2004
    Location
    Toronto
    Posts
    76
    Default
    i think you can safely rule out the zeiss lens. the ex-1 has exhibited some weird CA in certain situations...dunno about the letus.
  8. Collapse Details
    #8
    Join Date
    Feb 2008
    Location
    Colorado, USA
    Posts
    55
    Default
    Balster,
    I have the same problem with my Extreme. (Actually, it's more of a EX1 problem.) I've tried adjusting the gg screen, which didn't really help and I wouldn't recommend it. I've also mounted the Extreme slightly offset from the EX1. What I did was turn the adapter to the left (looking from the front) and tightened the three screws on the 77mm thread. There is a slight gap between the adapter and the thread ring on the right side (looking from the front again) and no gap on the left side. (Make sense?)
    Well, I found this somewhat corrects the blurry right side and leaves the left side in focus.
  9. Collapse Details
    #9
    Senior Member ryvac's Avatar
    Join Date
    Feb 2008
    Location
    LA
    Posts
    1,400
    Default
    is this common stuff for Letus Extreme users??
    I thought the extreme has the sharpest image amoung all adapters???
  10. Collapse Details
    #10
    Join Date
    Feb 2008
    Location
    Posts
    98
    Default
    Purple fringe:
    Actually I do suspect it to be a lens problem since the center of the image has no fringing... Also when I close the aperture the fringing stops... But I would guess the achromat and not the Zeiss lens.
    Can you guys post your shots to compare?
    You can download the res chart here: http://www.s106.com/blog/wp-content/...3-reschart.pdf
Posting Permissions
  • You may not post replies
  • You may not edit your posts
