Curious if anyone has experience with this.
i've heard of "instant HD" and also know that you can "export / Quicktime Conversion" and choose an HD flavor... results vary. What about after effects ?
Or hardware based ? Example, going from a SDI out on mini-dv deck into AJA and coming back out onto HD-CAM ?
thanks in advance.
michael
Results 1 to 8 of 8
11-18-2007 11:20 AM
Senior Member
- Join Date
- Aug 2007
- Posts
- 153
11-18-2007 11:55 AM
I'm not too familiar with that last option you chose.
I think your best bet is to export your piece as a series of TIFFs and take it to a professional post-house.
11-18-2007 01:42 PM
Senior Member
- Join Date
- Dec 2005
- Location
- Lawrence, KS
- Posts
- 121
11-18-2007 08:17 PM
I've heard of people doing up-rez through Shake before. I'm sorry I can't cite any specific examples, but hope it can give you somewhere to start. Some post houses use proprietary tools to do up-rez, so you would have to go through them to do it.
11-18-2007 11:01 PM
4:2:0 doesn't leave a lot to up-rez. After effects does a decent job. It takes a lot of tweaking, though. Paying for anything else seems kinda silly, unless you've got the next Zapruder film.
Senior Member
- Join Date
- Aug 2007
- Posts
- 153
11-19-2007 12:34 PM
Does the color space affect that?
In which case, would having an Andromeda DVX exported as say like 830x1540 (1.85:1) TIFFs yield good uprezzing to 1080p?
Like, next to no loss in quality?
11-19-2007 02:48 PM
If you have chroma subsampling, you will notice it on an uprez, because you have such a small amount of data to begin with. If you mean 8 vs 16-bit color, you'll also see a difference, but not as much as the difference between 4:2:0 and 4:4:4.
If your original source is 1540x830 4:4:4 10-bit tiffs, then you've got 4x the luminance data and 16x the chrominance data of standard MiniDV, plus 4x the color depth.
As a comparison, the HVX has about 3% more luminance data and about half the chrominance data in DVCProHD 1080, and 1/4 the color depth, so I would expect that the Andromeda would give the HVX a run for its money in that case, particularly in colorful shots.
Senior Member
- Join Date
- Aug 2007
- Posts
- 153
11-20-2007 12:33 PM
Thanks man. Appreciate your ability to give me the important info. in a terse, understandable way.
Highest Quality HD uprez for DVX ?
