Page 5 of 5 FirstFirst 12345
Results 41 to 48 of 48
  1. Collapse Details
    #41
    DVXuser Sponsor Dennis Wood's Avatar
    Join Date
    Apr 2005
    Location
    Thunder Bay, Ontario, Canada
    Posts
    2,092
    Default
    Barry, what's your suggestion with regard to a decent light meter? I'll run some tests on the HV20 and XH-A1 cams here to correlate IRE and f stops. I would guess the 8 bit limitation will limit an HDV/DV cam to 5 stops, with an extra stop dynamic thrown in for knee and stretch at the high/low end of the curve. Based on my research, I'd also assume the predictions will be easiest in the 40-60 IRE range? I was using this as a base: http://www.24pdigitalcinema.com/cinegamma.pdf
  2. Collapse Details
    #42
    Default
    I use a Sekonic L508-C, but that's way overkill for measuring reflected light off a white card, you could use almost any halfway decent light meter for that. $150 or so should get you completely set up.
  3. Collapse Details
    #43
    Join Date
    Apr 2005
    Location
    Posts
    2,092
    Default
    Actually not overkill as we're setting up a small studio in our new facility :-) I'll check that unit out...and thanks for the suggestion.
  4. Collapse Details
    I would like to place an order for the flip.
    #44
    Default
    Dennis,
    I am a previous Brevis owner - and I am shooting two productions on November 2nd. I want to utilize my HV20+Brevis combination for these shoots but in order to do so - I need the flip BADLY.
    Can I place an order for the next available flip module? I need one as soon as possible...
    Cris
  5. Collapse Details
    #45
    Join Date
    Apr 2005
    Location
    Posts
    2,092
    Default
    Cris, pm me. We won't have the engineered optics in place, but we definitely have flip modules on hand. There is a temporary (works, but not ideal) workaround on the HV20 :-)
  6. Collapse Details
    #46
    Senior Member dan's Avatar
    Join Date
    Mar 2005
    Location
    Vancouver, BC
    Posts
    488
    Default
    Edited latter. Problem solved.
    Best,
    Dan
    Cheers,
    Dan
  7. Collapse Details
    #47
    Join Date
    Apr 2005
    Location
    Posts
    2,092
    Default
    Dan, check your pm's.
  8. Collapse Details
    #48
    Cinematographiliac DC's Avatar
    Join Date
    Jan 2004
    Location
    Los Angeles, California USA
    Posts
    2,096
    Default
    Thread revival!
    Does anybody know of a way to pair Cinevate's Flip Module with Cinemek's G35 (Nikon mount) adapter?
    PANASONIC AF100 - SIGMA SD1 still photography -
    AVID Symphony
    editing/grading
    - ADOBE suite
    For Hire - Los Angeles based, World Traveler
    I just saved a bunch of money on my car insurance by canceling it.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
