Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 24
  1. Collapse Details
    #11
    Default
    I praised him, then I said "er, hold on, I found a problem". I then verified (as stated in the article) that even the $11,000 mini35 has the same problem (the static grain effect on higher shutter speeds). And therefore, if the guys with the premium "best" adapter on the market can't fix it, and ever vibrating adapter has the same issue, then I decided that it isn't anything to worry about with the Letus either. Just be aware of it, know when it happens, and if you can't avoid it, then the Letus (or any other vibrating adapter) is not for you. But as long as you avoid faster shutter speeds the problem becomes a non-problem.
  2. Collapse Details
    #12
    Senior Member marketmd's Avatar
    Join Date
    Aug 2007
    Location
    New York, NY
    Posts
    436
    Default
    Thanks for the clarification, Barry. Your thoroughness is really a great asset to this forum.
  3. Collapse Details
    #13
    Lucky Duck disjecta's Avatar
    Join Date
    May 2004
    Location
    Pine Lake, Seattle
    Posts
    3,619
    Default
    Quote Originally Posted by SamKam View Post
    Barry, Steve-
    Thanx for taking the time to do the write-up. I purchased the FE based on Steve's footage and Barry's earlier positive comments and couldn't be more pleased.
    One question, do you know of a way to mount Leica lenses of the kind that fit on the M6 to either the Canon or Nikon mount of the FE?
    Sounds like you are talking about some kind of adapter that would allow you to connect that kind of lens. Not sure where to direct you....maybe speak to someone at a place like B&H Photo or your local photo shop.
  4. Collapse Details
    #14
    Default
    well well just find out great news from letus there is a new version
    the letus extreme
    take a look on the site http://www.adapterplace.com
    ram shani
    cinematographer
    tel-aviv
  5. Collapse Details
    #15
    Senior Member 24fps4ever's Avatar
    Join Date
    Jan 2007
    Location
    texas
    Posts
    277
    Default
    I was just worried about a the vibrating motor, when on a tripod doing a still video shot if the adapter is on is there any noticible shaking due to the adapter? anything at all that will be noticed in the footage?
    that is going to be the deal maker for me personally
    I will always direct, in hollywood actors and musictians wanna direct and directors wanna act....ohh madness... I will never lose my "direction"
    -me
  6. Collapse Details
    #16
    Default
    No noticeable shaking whatsoever. I could feel the slightest tremor in the tripod handle, but the picture was rock steady.
    I guess it depends on your tripod too; a lightweight (i.e., flimsy) tripod is more likely to be susceptible to something like that. Even so, I doubt the very mild vibration of the L35FE motor would cause any visible effect on any reasonable tripod.
  7. Collapse Details
    #17
    Senior Member DerrickTempleton's Avatar
    Join Date
    May 2006
    Location
    North Hollywood, CA
    Posts
    436
    Default
    so how does the FE compare to the Letus Extreme and Letus Economy?
    edit: just read all 21 pages of http://www.dvxuser.com/V6/showthread.php?t=110531
    very exciting stuff!
  8. Collapse Details
    #18
    Default
    The FE is a great adapter for the price. The Extreme is a better adapter, for a higher price. Can't comment on the Economy because I haven't seen one of those; from the specs it sounds like it delivers most of the benefits of the Extreme for only a small increase in price over the L35FE.
  9. Collapse Details
    #19
    Junior Member evon's Avatar
    Join Date
    Jan 2008
    Location
    LONDON, UNITED KINGDOM
    Posts
    5
    Default
    Some important tips that can make your short film the best it can be
    Here is a list of some of the most important elements to keep in mind when making a short film. Following these guidelines will help you avoid the more common pitfalls. While these are only suggestions, they will almost certainly improve both your film and your filmmaking experience.
    Make sure you have a story worth telling
    Would you sit through the short film if someone else had made it? The answer for a surprising number of shorts is No. Ask yourself this question before you even start writing the script.
    Don’t start production without a budget
    Films, no matter how simple, cost money -- and money is always limited. By making sure you have a budget (a simple spreadsheet will do), you can decide in advance where you want to spend whatever money you have. Without a budget, you can almost guarantee that you will either spend more money than you plan, or end up without the finished film.
    Get all clearances before shooting
    You need, need, NEED releases from actors, music/artwork contributors, and anyone else who produces content that appears in the film. Getting clearance signatures before the shoot is simple and takes you moments. After the shoot, it can be difficult to impossible. Don’t get caught, do it now.
    Make the film shorter than you want
    Writer/directors always often leave things in the movie that the audience can really do without. It’s so painful to trim away things that were difficult to shoot. Make sure you do it. Your audience will thank you.
    When using non-professional actors, cast with personality
    I believe bad acting is so common in short films because people are asked to play characters that don’t resemble their personalities. A dirt-poor professional actor can portray the swagger and confidence of a billionaire – but most amateurs can’t. If your lead is an anal-retentive tightwad, don’t cast a slovenly slacker to play him.
    Invest in good sound
    Bad sound makes many short films (even ones with good stories) unbearable. There are no real replacements for a decent boom mike. Beg, buy, or borrow one and it will triple the chances your film will be watch-able.
    Fix it now, not in post-production
    Without Digital Domain or WETA working for you, most post-production fixes don’t look/sound very good and take A LOT of time. If you have a mistake in framing, dialogue, or anything else that can be fixed on the shoot, do it!
    Don’t zoom in a shot
    Don’t touch that zoom switch! A really good cameraman can make a zoom look OK. In almost all cases, though, using zooming is the hallmark of a sad effort. If you need to push in on a subject, use a dolly, camera glider, or a cut.
    Know the indie/short film clichés
    The most common clichés include using dream sequences, many dissolves/wipes, long credit sequences, or waking to a ringing alarm clock. There even seem to be a few websites devoted exclusively to citing indie/short film clichés. Know what the clichés are so you can make an intelligent choice on whether to use them or not.
    Unless you’re shooting on film, avoid night exteriors
    Darkness is the enemy of most camcorders. You’ll become acquainted with noise, color shifting, definition drop-out, and more if you choose to shoot at night without a medium size lighting package. It’s usually a lot easier to change the script than deal with all these problems
    compiled Engineer Evon
  10. Collapse Details
    #20
    Senior Member ecking's Avatar
    Join Date
    Apr 2005
    Location
    Toronto
    Posts
    1,369
    Default
    Why post this here in this old review?
    Why do there have to be puppets like Frank?
    My Twitter
Posting Permissions
  • You may not post replies
  • You may not edit your posts
